Realization of an automated remote maintenance system
  • Benoit.T
    • May 2019
    I come to you today because I am a beginner with this tool.
    To contextualize, the person in my company who was taking care of Zabbix to resign and I am the one who got his current project back.
    The objective of this project is to create an automated remote maintenance system on the 200 existing hosts.
    Basically, every month an email or report should be sent to the customer with the following information:
    - Check if processor usage is less than 60%.
    - Check if the use of the ram is less than 20%.
    - Check if the capacity of the different storage disks is less than 10%.
    - Check if the antivirus is active
    - Check HyperV replication
    - Ckecker if raids are in place
    - Check backups / logs if possible
    I would like to know if the realization of this project is possible or not? If so, can you guide me where to start?
    Sincerely,
    Benoit T.
  • Benoit.T
    • May 2019
    Someone can help me ? Sincerely, Benoit T.
