Unit Convertion ( Volts )
  • carvelasc
    • Jun 2019
    Hi all
    I monitor a IoT device( WISE-4012E) using modbus and so far so good .
    The problem is that the device sends metrics decimal number in form 'nnnn' witch represents volts in range 0V - 10V . I have create the in zabbix the necessary item and in Unit i put V ( Volts )
    Then the zabbix makes the conversion and the results is in KV . In other words the conversion is not correct expecting the value n.nnn V . Is any way to define the conversion manual ? or any idea how can i correct this
  • Hamardaban
    • May 2019
    • 2713
    just use preprocessing and multiply by 0.001
    • carvelasc
      • Jun 2019
      Thanks works fine now
