Zabbix scripts
  • tbtron
    • Jun 2019
    Zabbix scripts
    Zabbix noob here, so apologies if this seems obvious to you.
    I have script on my zabbix server just for checking tcp port 3341. I can run this manually via the GUI
    I want zabbix server (not agent) to run this script continuously and then trigger an alert if the port is closed, on a specific host.
    All host are set up for SNMP and zabbix is inside our firewall so it only need to run the script againts host on the same network
    Very simple. Or so i thought.
    Can you anyone advise on the steps for this?
