Dashboard & widget
  • warp10
    • Apr 2019
    • 39
    Dashboard & widget
    Hi all,
    Could you tell me if it's possible to use this widget zabbix 3.2 with 4.2 ? it's very usefull , but where in 4.2 , is not in the list ?
  • sancho
    • Mar 2015
    • 301
    Hello warp,
    It is the widget called "Problems by severity", since several versions the green background changed to white.
    • warp10
      • Apr 2019
      • 39
      Thanks Sancho
