I have this mib. I want to use it like a template on Zabbix. How can handle this or can anyone give me the template from this mib ?
-- File Name : SANGFOR-GENERAL-MIB.txt
-- Date : Mon Oct 11 17:01:21 CST 2010
-- Author : WebNMS Agent Toolkit C Edition - MibEditor 6
SANGFOR-GENERAL-MIB DEFINITIONS ::= BEGIN
IMPORTS
DisplayString, PhysAddress, snmp, system
FROM RFC1213-MIB
TEXTUAL-CONVENTION, DisplayString
FROM SNMPv2-TC
OBJECT-TYPE
FROM RFC-1212
enterprises
FROM RFC1155-SMI;
-- TEXTUAL-CONVENTIONS --
PhysAddress ::= OCTET STRING
DisplayString ::= OCTET STRING
org OBJECT IDENTIFIER
::= { iso 3 }
dod OBJECT IDENTIFIER
::= { org 6 }
internet OBJECT IDENTIFIER
::= { dod 1 }
private OBJECT IDENTIFIER
::= { internet 4 }
enterprises OBJECT IDENTIFIER
::= { private 1 }
sangfor OBJECT IDENTIFIER
::= { enterprises 35047 }
general OBJECT IDENTIFIER
::= { sangfor 1 }
product OBJECT IDENTIFIER
::= { sangfor 2 }
wac OBJECT IDENTIFIER
::= { product 12 }
sfDeviceDescr OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "Device name&model"
::= { general 1 }
sfSysDate OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "System's date."
::= { general 2 }
sfSysCpuCostRate OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "Cpu current cost percentage.The unit is %."
::= { general 3 }
sfSysFreeMemory OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "Free memory."
::= { general 4 }
sfDiskTable OBJECT-TYPE
SYNTAX SEQUENCE OF SfDiskEntry
ACCESS not-accessible
STATUS mandatory
DESCRIPTION "Description"
::= { general 5 }
sfDiskEntry OBJECT-TYPE
SYNTAX SfDiskEntry
STATUS mandatory
DESCRIPTION "Row Description"
INDEX { diskIndex }
::= { sfDiskTable 1 }
SfDiskEntry ::= SEQUENCE {
diskIndex INTEGER,
sfFilesystemName DisplayString,
sfDiskSize DisplayString,
sfDiskUsed DisplayString,
sfDiskAvail DisplayString,
sfDiskUsedPercent DisplayString
diskIndex OBJECT-TYPE
SYNTAX INTEGER
STATUS mandatory
DESCRIPTION "Column Description"
::= { sfDiskEntry 1 }
sfFilesystemName OBJECT-TYPE
SYNTAX DisplayString
ACCESS read-only
STATUS mandatory
::= { sfDiskEntry 2 }
sfDiskSize OBJECT-TYPE
ACCESS read-only
STATUS mandatory
::= { sfDiskEntry 3 }
sfDiskUsed OBJECT-TYPE
ACCESS read-only
STATUS mandatory
::= { sfDiskEntry 4 }
sfDiskAvail OBJECT-TYPE
ACCESS read-only
STATUS mandatory
::= { sfDiskEntry 5 }
sfDiskUsedPercent OBJECT-TYPE
ACCESS read-only
STATUS mandatory
::= { sfDiskEntry 6 }
CpuLoadAvg OBJECT IDENTIFIER
::= { general 6 }
sfcpuName OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "CPU Name"
::= { CpuLoadAvg 1 }
sfCpuLoadLast1Min OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "load average in past 1 minute."
::= { CpuLoadAvg 2 }
sfCpuLoadLast5Min OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "load average in past 5 minute."
::= { CpuLoadAvg 3 }
sfCpuLoadLast15Min OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "load average in past 15 minute."
::= { CpuLoadAvg 4 }
sfEnableDoubleHost OBJECT-TYPE
SYNTAX INTEGER ( 0 .. 1 )
ACCESS read-only
STATUS mandatory
DESCRIPTION "0--disable.1--enable"
::= { general 7 }
dhcp OBJECT IDENTIFIER
::= { general 8 }
sfEnableDHCP OBJECT-TYPE
ACCESS read-only
STATUS mandatory
DESCRIPTION "0--disable.1--enable."
::= { dhcp 1 }
sfDHCPTable OBJECT-TYPE
SYNTAX SEQUENCE OF sfDHCPEntry
STATUS mandatory
DESCRIPTION "Table of each interface's DHCP info"
::= { dhcp 2 }
sfDHCPEntry OBJECT-TYPE
SYNTAX sfDHCPEntry
STATUS mandatory
DESCRIPTION "entry of sfDHCPTable, when dhcp is disabled it has only one entry with zeros"
INDEX { dhcpIndex }
::= { sfDHCPTable 1 }
sfDHCPEntry ::= SEQUENCE {
dhcpIndex INTEGER,
sfIfName OCTET STRING,
sfNumOfTotalIpAddr INTEGER,
sfNumOfLeftIp INTEGER,
sfNumOfOccupyIp INTEGER,
dhcpIndex OBJECT-TYPE
SYNTAX INTEGER
STATUS mandatory
DESCRIPTION "index of sfDHCPEntry"
::= { sfDHCPEntry 1 }
sfIfName OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "network interface's name ."
::= { sfDHCPEntry 2 }
sfNumOfTotalIpAddr OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "The total IP address's number in IP pool."
::= { sfDHCPEntry 3 }
sfNumOfLeftIp OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "The number of left."
::= { sfDHCPEntry 4 }
sfNumOfOccupyIp OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "The number which already be used."
::= { sfDHCPEntry 5 }
sfSysTotalMemory OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "Total memory."
::= { general 9 }
sfSysName OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "System's Name"
::= {general 10}
sfSysSupplier OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "System's supplier"
::= {general 11}
sfSysIp OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "System Ip address"
::= {general 12}
apinfo OBJECT IDENTIFIER
::= { wac 1 }
sfApInfoTable OBJECT-TYPE
SYNTAX SEQUENCE OF sfApInfoEntry
STATUS mandatory
DESCRIPTION "Table of each ap's info"
::= { apinfo 1 }
sfApInfoEntry OBJECT-TYPE
SYNTAX sfApInfoEntry
STATUS mandatory
DESCRIPTION "entry of sfApInfoTable"
INDEX { apinfoIndex }
::= { sfApInfoTable 1 }
sfApInfoEntry ::= SEQUENCE {
apinfoIndex INTEGER,
sfApName OCTET STRING,
sfApHardver OCTET STRING,
sfApSeriNum OCTET STRING,
sfApMAC OCTET STRING,
sfApIP OCTET STRING,
sfApOnlineTime OCTET STRING,
sfApStatus OCTET STRING,
sfSsid1 OCTET STRING,
sfRadioType1 OCTET STRING,
sfPhyMode1 OCTET STRING,
sfChannel1 INTEGER,
sfFrequency1 OCTET STRING,
sfSsid2 OCTET STRING,
sfRadioType2 OCTET STRING,
sfPhyMode2 OCTET STRING,
sfChannel2 INTEGER,
sfFrequency2 OCTET STRING,
sfApUserNum INTEGER,
apinfoIndex OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "index of sfApInfoEntry"
::= { sfApInfoEntry 1 }
sfApName OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's Name"
::= { sfApInfoEntry 2 }
sfApHardver OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's hardware version"
::= { sfApInfoEntry 3 }
sfApSeriNum OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's seriers number"
::= { sfApInfoEntry 4 }
sfApMAC OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's Mac"
::= { sfApInfoEntry 5 }
sfApIP OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's ip"
::= { sfApInfoEntry 6 }
sfApOnlineTime OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's online time"
::= { sfApInfoEntry 7 }
sfApStatus OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's status"
::= { sfApInfoEntry 8 }
sfSsid1 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's all wlan ssid(2.4G)"
::= { sfApInfoEntry 9 }
sfRadioType1 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's radio type"
::= { sfApInfoEntry 10 }
sfApPhyMod1 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's radio Phy mode 2.4G"
::= { sfApInfoEntry 11 }
sfChannel1 OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's chanel 2.4G"
::= { sfApInfoEntry 12 }
sfFrequency1 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's frequency 2.4G"
::= { sfApInfoEntry 13 }
sfSsid2 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's all wlan ssid(5.8G)"
::= { sfApInfoEntry 14 }
sfRadioType2 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= { sfApInfoEntry 15 }
sfApPhyMod2 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's radio Phy mode 5.8G"
::= { sfApInfoEntry 16 }
sfChannel2 OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's chanel 5.8G"
::= { sfApInfoEntry 17 }
sfFrequency2 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's frequency 5.8G"
::= { sfApInfoEntry 18 }
sfApUserNum OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "AP's User number"
::= { sfApInfoEntry 19 }
sfApOnlineNum OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "wac's online ap number"
::= { apinfo 2 }
sfApOffNum OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "wac's offline ap number"
::= { apinfo 3 }
sfApDepositNum OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "wac's deposit ap number"
::= { apinfo 4 }
userinfo OBJECT IDENTIFIER
::= { wac 2 }
sfUserInfoTable OBJECT-TYPE
SYNTAX SEQUENCE OF sfUserInfoEntry
STATUS mandatory
DESCRIPTION "Table of each user's info"
::= { userinfo 1 }
sfUserInfoEntry OBJECT-TYPE
SYNTAX sfUserInfoEntry
STATUS mandatory
DESCRIPTION "entry of sfUserInfoTable"
INDEX { userinfoIndex }
::= { sfUserInfoTable 1 }
sfUserInfoEntry ::= SEQUENCE {
userinfoIndex OCTET STRING,
sfUserName OCTET STRING,
sfUserIP OCTET STRING,
sfUserTermType OCTET STRING,
sfUserMAC OCTET STRING,
sfUserApMAC OCTET STRING,
sfUserSSID OCTET STRING,
sfUserPhy OCTET STRING,
sfUserVlanID INTEGER,
sfUserOnline OCTET STRING,
sfUserRSSI OCTET STRING,
sfUserUpRate OCTET STRING,
sfUserDownRate OCTET STRING,
userinfoIndex OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "index of sfUserInfoEntry"
::= { sfUserInfoEntry 1 }
sfUserName OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "user's Name"
::= { sfUserInfoEntry 2 }
sfUserIP OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "user's IP Address"
::= { sfUserInfoEntry 3 }
sfUserTermType OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "user's terminal type"
::= { sfUserInfoEntry 4 }
sfUserMAC OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "user's MAC Address"
::= { sfUserInfoEntry 5 }
sfUserApMAC OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "user's AP MAC Address"
::= { sfUserInfoEntry 6 }
sfUserSSID OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's ssid"
::= { sfUserInfoEntry 7 }
sfUserPhy OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's client phy"
::= { sfUserInfoEntry 8 }
sfUserVlanID OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's vlan id"
::= { sfUserInfoEntry 9 }
sfUserOnline OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's online time"
::= { sfUserInfoEntry 10 }
sfUserRSSI OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's rssi"
::= { sfUserInfoEntry 11 }
sfUserUpRate OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's up_rate"
::= { sfUserInfoEntry 12 }
sfUserDownRate OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
DESCRIPTION "User's down_rate"
::= { sfUserInfoEntry 13 }
sfUserNum OBJECT-TYPE
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
DESCRIPTION "Online user number"
::= { userinfo 2 }
egpNeighborLoss TRAP-TYPE
ENTERPRISE snmp
VARIABLES { egpNeighAddr }
DESCRIPTION "egpNeighborLoss"
::= 5
warmStart TRAP-TYPE
ENTERPRISE snmp
DESCRIPTION "warmStart"
::= 1
coldStart TRAP-TYPE
ENTERPRISE snmp
DESCRIPTION "coldStart"
::= 0
linkUp TRAP-TYPE
ENTERPRISE snmp
VARIABLES { ifIndex }
DESCRIPTION "linkUp"
::= 3
linkDown TRAP-TYPE
ENTERPRISE snmp
DESCRIPTION "linkDown"
::= 2
authenticationFailure TRAP-TYPE
ENTERPRISE snmp
DESCRIPTION "authenticationFailure"
::= 4
enterpriseSpecific TRAP-TYPE
ENTERPRISE sangfor
VARIABLES { sfSysIpAddr }
DESCRIPTION "enterpriseSpecific"
::= 6
END
IMPORTS
FROM RFC1213-MIB
FROM SNMPv2-TC
OBJECT-TYPE
FROM RFC-1212
enterprises
FROM RFC1155-SMI;
::= { iso 3 }
::= { org 6 }
::= { dod 1 }
::= { internet 4 }
::= { private 1 }
::= { sangfor 1 }
::= { sangfor 2 }
::= { product 12 }
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= { general 1 }
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= { general 2 }
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
::= { general 3 }
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= { general 4 }
STATUS mandatory
::= { general 5 }
SYNTAX SfDiskEntry
STATUS mandatory
INDEX { diskIndex }
diskIndex INTEGER,
SYNTAX INTEGER
STATUS mandatory
ACCESS read-only
STATUS mandatory
ACCESS read-only
STATUS mandatory
ACCESS read-only
STATUS mandatory
ACCESS read-only
STATUS mandatory
ACCESS read-only
STATUS mandatory
::= { general 6 }
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
ACCESS read-only
STATUS mandatory
::= { general 7 }
::= { general 8 }
ACCESS read-only
STATUS mandatory
::= { dhcp 1 }
STATUS mandatory
::= { dhcp 2 }
SYNTAX sfDHCPEntry
STATUS mandatory
INDEX { dhcpIndex }
dhcpIndex INTEGER,
SYNTAX INTEGER
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= { general 9 }
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= {general 10}
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= {general 11}
sfSysIp OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
::= {general 12}
::= { wac 1 }
STATUS mandatory
::= { apinfo 1 }
STATUS mandatory
sfChannel1 INTEGER,
sfChannel2 INTEGER,
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
sfApMAC OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
sfApIP OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
sfSsid1 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
sfSsid2 OBJECT-TYPE
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
::= { apinfo 2 }
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
::= { apinfo 3 }
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
::= { apinfo 4 }
::= { wac 2 }
STATUS mandatory
::= { userinfo 1 }
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX OCTET STRING
ACCESS read-only
STATUS mandatory
SYNTAX INTEGER
ACCESS read-only
STATUS mandatory
::= { userinfo 2 }
ENTERPRISE snmp
::= 5
warmStart TRAP-TYPE
ENTERPRISE snmp
::= 1
coldStart TRAP-TYPE
ENTERPRISE snmp
::= 0
linkUp TRAP-TYPE
ENTERPRISE snmp
::= 3
linkDown TRAP-TYPE
ENTERPRISE snmp
::= 2
ENTERPRISE snmp
::= 4
ENTERPRISE sangfor
::= 6
END
