Zabbix + SCVMM
  • zumi_fi
    • Sep 2018
    • 10
    Zabbix + SCVMM
    Hello!
    I've made a script that will print in JSON all Hyper-V snapshots.
    The output is formatted correctly:
    "data":
    {"{#VM}":"SNAPSHOTNAME1"},
    {"{#VM}":"SNAPSHOTNAME2"},
    {"{#VM}":"SNAPSHOTNAME3"},
    I was struggling to get this to work as Zabbix all the time told me "Value should be a JSON object."
    After some testing I noticed that Zabbix Agent doesn't have rights to run any Get-SCVM powershell commands.
    I also tried to import the "virtualmachinemanager" snap-in to the script but it doesn't help.
    Does anyone have any good ideas how I can overcome this issue?
