Hi Guys
I am a bit of newbie to zabbix and linux for that matter so I downloaded and began using the appliance version. I have invested time in working out Hosts, items, triggers etc and that all works great now but I am stuck on one thing which I would really appreciate some help.
I want to be able to ping agentless hosts using simplecheck but my zabbix install keeps telling me I need fping installed. I have worked my way through the forums and all i can find is a list of commands I need to run and its supposed to work. The commands are:
chown root:zabbix /usr/sbin/fping
chmod 4710 /usr/sbin/fping
as per the manual
this dosent fix it for me, correct me if I am wrong but I log into my appliance via the putty shell, login as root and then run these commands (hopefully this is correct as I said not much linux experience here)
I have read the other posts but its not making sense to me, please help I like the product and I am enjoying using it but obviously my knowledge is letting me down here.
Simon
as per the manual
Simon
