Extracting a value from a Json to call another URL
  • vincent@cream
    • Jun 2019
    I'm new to Zabbix, and trying to do the following :
    - Create a HTTP agent item to retrieve a value from a Json (in Preprocessing JsonPath i'm guessing)
    - Use this value in a dependent Item (URL parameter of previously found value) to check the final result (Json response from that second URL)
    Am I doing it the right way ? i'm a bit struggling, thanks in advance for some help
