Graph multiple host
  • mururoa
    • Jul 2014
    • 11
    Graph multiple host
    I'm new to zabbix so dont hurt too much !
    I use zabbix 2.2
    I try to view multiple hosts in monitoring/graphs but all I get is only one host at a time, even if I select group:all and host:all. All I get is last host selected.
    Same with firefox or chrome.
    Is that normal ?
  • Alberto Freire
    • Jul 2014
    • 24
    If I understand correctly, you want all graphics are displayed in "Monitoring > Graphs"?
    Not that way. You can create "screens" on "Monitoring > Screens" with multiple graphs.
    • mururoa
      • Jul 2014
      • 11
      Thanks. That's ok but I was looking for some kind of automatised graphs.
      Like one graph for cpu load for all hosts of group 'application hosts' (one color by host) or one graph for each host of group 'core server' for memory usage (one graph by host).
      And if I add an host graphs are updated.
      • Alberto Freire
        • Jul 2014
        • 24
        I know not if exist this feature, but you can manually to do this:
        • filipp.sudanov
          • May 2014
          • 137
          The feature you requesting is still awaiting implementation - see here.
          • mururoa
            • Jul 2014
            • 11
            Alberto, that's what I did in the end.
            Filip, that's what I need. I dont want to add one graph each time I add one server. We are in the cloud era hey ! I'm gonna push this feature request.
            • tchjts1
              • May 2008
              • 1605
              If you create a graph at the template level, the graph is then available for all hosts that have that template assigned to them.
              Then the next best thing you can do is create a screen and make each graph dynamic. Then from the dropdown boxes of Monitoring --> Screens, you simply select the hostgroup and host that you want data from and they will populate the data onto your graphs.
              • mpasha06
                • Jan 2014
                • 15
                Multiple nodes in a single graph
                1. Select node and go to the Graph
                2. Create Graph
                3. In 'Items' select multiple nodes items to monitor.
                4. Click save.
