Upgrade ZAbbix
  • warp10
    • Apr 2019
    • 39
    Upgrade ZAbbix
    Hi all,
    I read the doc about upgrade but is it for standalone server, could you tell me how to update zabbix with two servers, one with database and another with zabbix server + web access , how to update the schema database with the 4.2 version there is more table (146) ? with the yum upgrade .
    thx
  • Mike2K
    • Oct 2018
    • 60
    The upgrade is for the zabbix server only. The database server doesn't run any zabbix related stuff except for the monitoring agent perhaps.
    Just upgrade the server, it will take care of upgrading your database.
    You can see that by tailing to log file as soon as you start the zabbix-server service after the upgrade.
    • warp10
      • Apr 2019
      • 39
      Hi Mike2K,
      Ok Thanks for the help, I go to the test...
