Dependent tests
  • Spence572
    • Jun 2019
    Dependent tests
    Hi all,
    I’ve been struggling with this for a while. I have 4 tests (items) that work fine on their own (let’s call them test1, test2, test3 and test4). All of the tests are running different Linux scripts and the results are always OK or FAIL.
    Now what I’m after is test1 to run and if the result is FAIL then run test2 and test3 but if the result of test1 is OK then run test4.
    Please can you provide some examples to help me?
    Thanks in advance.
    Paul
  • Mike2K
    • Oct 2018
    • 60
    what have you tried so far?
    • Spence572
      • Jun 2019
      Hi Mike2K,
      Thanks for the reply and sorry it's taken me a while to get back to you.
      So far I have tried reading all the documentation I can find on the Zabbix site and also other websites which haven't really helped.
      In terms of trying things within Zabbix, I have tried using the dependency option within the triggers, is this the correct place to try?
      Paul
