sending triggers every 30 minutes until ACKED, how to setup?
  • robertchen
    • Jun 2014
    • 39
    I need to send triggers every 30 minutes until ACKED, how to setup?
    my zabbix is 2.2.4.
  • Colttt
    • Mar 2009
    • 878
    configuration->actions->create action
    create you own action.. under operations:
    down below you see "conditions" somthing like "Event acknowledged = Not Ack"
    and in the top of chtis operations you see "Default operation step duration:" here can you set it to 1800, and step from 1 to 0..
    ok?!
    Debian-User
    Sorry for my bad english
