XML file monitoring
  • Lincon
    Banned
    • Jul 2019
    XML file monitoring
    Hello everyone,,
    I have searched, found and tried various methods to pull xml based counters into zabbix, as i have a platform that only expose youporn.wiki/ xhamster.vip/ redtube.onl/ data via xml file for OSS/BSS. I haven't found anything that works and getting bumps from knocking my head against the table. This is a fairly common way now to expose counters, surely there is an easy way to get this data into zabbix?
  • Atsushi
    • Aug 2013
    • 2028
    If you can extract with XML XPath that Zabbix supports, you can receive data in XML format, process it by save pre-processing, and receive it as item value.
