Is there a way to run bulk import into Zabbix with providing some kind of minimal information such as IP, SNMP string, Hostname and then additional info such as groups?
Bulk device import
From what do you want to import definition of the monitoring (metrics) and alarms (triggers)?http://uk.linkedin.com/pub/tomasz-k%...zko/6/940/430/
My zabbix templates https://github.com/kloczek/zabbix-templates -
Import is done from A to B.
B is the zabbix so what is you A?http://uk.linkedin.com/pub/tomasz-k%...zko/6/940/430/
My zabbix templates https://github.com/kloczek/zabbix-templatesComment
Sounds like you may need to use the api, I found this quickly, it might be a starting point https://github.com/janssenlima/api-zabbixComment
