Is there a way get trigger arguments passed to trigger fucntion?
  • mpolitaev
    • Jun 2015
    • 32
    Hello team!
    I know there is macro ITEM.LASTVALUE which represent last value came into item which invoke trigger.
    But can i see with trigger like this:
    {Template App Zabbix Agent:agent.ping.nodata(5m)}=1
    Alert like this:
    "Zabbix agent unreachable TRIGGER.FUNCTION.ARGUMENT"
    TRIGGER.FUNCTION.ARGUMENT should be resolved to "5m" which is passed to trigger function "nodata()"
    Is there possible?
    Thank you.
  • Richi
    • Jun 2017
    as an possibility you could use a Macro for your Template.
    Template -- Macro:
    {$TRIGGER_NODATA_TIME}=>5m
    Trigger Name: "Zabbix agent unreachable {$TRIGGER_NODATA_TIME}"
    Item Setup: {Template App Zabbix Agent:agent.ping.nodata({$TRIGGER_NODATA_TIME})
    Trigger Condition: {Template App Zabbix Agent:agent.ping.nodata({$TRIGGER_NODATA_TIME})}=1
    Best Regards
    • mpolitaev
      • Jun 2015
      • 32
      Template -- Macro:
      Best Regards
      Thank you, I plan to do that, but curious if Zabbix has internal Macro.
      Zabbix don't has, right?
