Zabbix repository not working
  • KennyS
    • Jul 2019
    I am having trouble installing zabbix on Centos 7. I want to install all zabbix components but all the packages are not available..
    I don't know why it doesn't work, because I already installed the Zabbix repository:
    Thanks for your help,
  • Atsushi
    • Aug 2013
    • 2028
    As shown in the output of the yum command, the settings of the elrepo, epel-testing, epel, google-chrome and zabbix repositories seem to be duplicated. Check if there are duplicate settings in the /etc/yum.repos.d/ directory.
    Then, clear the yum repository cache once and try again.
    • KennyS
      • Jul 2019
      First of all, thanks for your reply.
      I checked my yum repository, but I don't really know if all my repo are useful or not (I am a newbie in Centos):
      Do you know which repo I should remove ?
      • Atsushi
        Atsushi commented
        It can not be determined just by looking at the file name. It is necessary to check which repository is set for each file.
    • KennyS
      • Jul 2019
      After searching a bit inside the repos, I finally found all the duplicate data, I removed them and now I just installed all the Zabbix component successfully.
      Thanks for your help !
