Slow Query Trigger Tag and Value
  • Richi
    • Jun 2017
    i have one slow Query which I dont get fixed. I hope someone can help me to find the cause.
    The Query itslef is done by the Zabbix Server:
    zabbix_server.log:
    29675:20190711:130650.872 slow query: 38.739595 sec, "select distinct tt.triggertagid,tt.triggerid,tt.tag,tt.value from trigger_tag tt,triggers t,hosts h,items i,functions f where t.triggerid=tt.triggerid and t.flags<>2 and h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=tt.triggerid and h.status in (0,1)"
    In the Slow Query Log of our Database I also see the same every 3minutes:
    # Time: 190711 13:03:50
    # User@Host: zabbix[zabbix] @ XXXX [XX.XX.XX.XX]
    # Thread_id: 29571539  Schema: zabbix  QC_hit: No
    # Query_time: 38.640142  Lock_time: 0.000048  Rows_sent: 1098189  Rows_examined: 3342564
    SET timestamp=1562843030;
    select distinct tt.triggertagid,tt.triggerid,tt.tag,tt.value from trigger_tag tt,triggers t,hosts h,items i,functions f where t.triggerid=tt.triggerid and t.flags<>2 and h.hostid=i.hostid and i.itemid=f.itemid and f.triggerid=tt.triggerid and h.status in (0,1);
    # Time: 190711 13:06:50
    # Query_time: 38.739229  Lock_time: 0.000051  Rows_sent: 1098189  Rows_examined: 3342564
    SET timestamp=1562843210;
    Version: Zabbix 4.0.0
    Database: MariaDB 5.5
    System Informations: Hosts 3899, Items 366161, Triggers 277904, Value per Second 2726.98
    Database Master cnf:
    [mysqld]
    max_allowed_packet=500M
    innodb_flush_log_at_trx_commit = 0
    innodb_doublewrite = 0
    innodb_support_xa = 0
    innodb_file_per_table = 1
    innodb_buffer_pool_size = 50G
    innodb_log_file_size = 6400M
    innodb_buffer_pool_instances = 50
    log-bin = mysql-bin
    server_id = 1
    expire_logs_days = 6
    sync_binlog = 1
    max_connections = 250
    Zabbix Server Config (non defaults):
    StartPollers=100
    StartPollersUnreachable=30
    StartTrappers=15
    StartPingers=35
    MaxHousekeeperDelete=15000
    CacheSize=4G
    CacheUpdateFrequency=120
    StartDBSyncers=8
    HistoryCacheSize=128M
    HistoryIndexCacheSize=64M
    TrendCacheSize=384M
    ValueCacheSize=384M
    Timeout=30
    LogSlowQueries=3000
    ExportDir=/var/export/zabbix/
    ExportFileSize=1000M
    Best Regards
    Richi
