Metrics & Prometheus with Zabbix
  • warp10
    • Apr 2019
    • 39
    Hi all,
    I would like to know if the node exporter (port:9100) is the only way for select metrics to zabbix , there is another way ? the link of prometheus with 9090 port too ?
    Thanks for your Help
  • pc99096
    • Oct 2011
    • 193
    same question, is it possible to get the metrics directly from prometheus server instead of node exporter?
    • nkastanas
      • Apr 2020
      Hi there,
      Node exporter default port is on 9100, Prometheus server gui is on port 9090 and also Prometheus server metrics are on ip:9090/metrics
      hope this helps
      NK
      • Semiadmin
        • Oct 2014
        • 1626
        Unfortunately, there isn't a possibility to get values from the Prometheus server via Zabbix prometheus checks. But you may receive last values by http-agent check from Prometheus server API.
        For example:
        http://<server_ip>:9090/api/v1/query?query=node_memory_MemFree
