Hi All,
I am new to access Zabbix API using python. When I was trying to get host information using user name and password it says invalid username and password.
Here is my python script
#!/usr/bin/env python
from pyzabbix import ZabbixAPI
from pprint import pprint
# Create ZabbixAPI class instance
zapi = ZabbixAPI("http://xx.xx.x.xxx/zabbix")
zapi.login("Admin", "{somepassword}")
print "Connected to Zabbix API Version %s" % zapi.api_version()
for h in zapi.host.get(output="extend"):
pprint(h)
Here is my output
[root@zabbix-vx-010101-1 html]# python monitoredhosts.py
Traceback (most recent call last):
File "monitoredhosts.py", line 6, in <module>
zapi = ZabbixAPI("http://10.21.1.239/zabbix")
File "/usr/lib/python2.7/site-packages/pyzabbix/api.py", line 171, in __init__
self._login(user, password)
File "/usr/lib/python2.7/site-packages/pyzabbix/api.py", line 201, in _login
self.auth = self.user.login(user=user, password=password)
File "/usr/lib/python2.7/site-packages/pyzabbix/api.py", line 90, in fn
args or kwargs
File "/usr/lib/python2.7/site-packages/pyzabbix/api.py", line 263, in do_request
raise ZabbixAPIException(err)
pyzabbix.api.ZabbixAPIException: {u'message': u'Application error.', u'code': -32500, u'data': u'Login name or password is incorrect.', 'json': "{'params': {'password': 'zabbix', 'user': 'Admin'}, 'jsonrpc': '2.0', 'method': 'user.login', 'id': '1'}"}
Can you please help me , where I am doing wrong. My username and password are correct I am able to login to UI with these credentials.
Appreciate your help
pprint(h)
Here is my output
args or kwargs
