How to add script to open host in client browser?
  • khansari
    • Mar 2019
    • 33
    I need to add a script to my zabbix server that can open browser with specific URL on Zabbix admin OS Client.
    For example if a host has a problem, I want to click on hostname in problem list and then click on my script "Browser".
    So Zabbix must open a new tab on my browser and goto the page with url => http://{HOST.NAME}
    How can i do this ?
    Regrads,
  • splitek
    • Dec 2018
    • 101
    I think by map and URL.
    • Hamardaban
      • May 2019
      • 2714
      At the problems section in the popup menu for HOST - no way. Only pretty deep coding. You can add a URL to the trigger, and then a link to it will be available through the popupmenu (label - URL) at the" trigger name" of problems view.
      • khansari
        • Mar 2019
        • 33
        Hello
        I added a custom link on popup menu into the file "menupopup.js"
        But i can't use Macro names like Hostname , So i can only add custom static url on popup menu.
        Is there any solution for add hostname macro in menupopup.js codes??
        Also when i added url into "inventory" section on host configuration, Is not show on problem popup or map popup. what is problem ?
