Zabbix 1.8.20 not sending email alerts
  • kristiaan_d
    • May 2009
    • 15
    Hi Guys,
    I have a Centos 6.5 Minimal install, running Zabbix 1.8.20 its a VERY basic setup at the moment as i am looking at moving away from Nagios to Zabbix but am struggling to make the change so far.
    I have intentionally broken a service on the Zabbix server so it reports to say there is a problem. However I have been unable so far to get any email alerts from Zabbix about the broken service.
    I have an action configured that says
    Maintenance status not in "maintenance"
    Trigger value = "PROBLEM"
    Trigger = "Zabbix server:Inetd is not running on {HOSTNAME}"
    Send message to User "Kris"
    We are using Microsoft Exchange 2010 on a separate server to handle emails, I can connect to the Exchange server from the Zabbix server via Telnet and send emails but I have so far been unable to get Zabbix to generate an email.
    Kris
  • jvalenzani
    • Sep 2010
    • 53
    Did you configure the mail server in Zabbix?
    • tchjts1
      • May 2008
      • 1605
      Another point to consider is that user "Kris" must have at least read privileges to that host in Zabbix GUI.
      • kristiaan_d
        • May 2009
        • 15
        https://www.zabbix.com/documentation...on#media_types
        Hi Yes i've configured the server within Zabbix and it uses the same settings that I use within Telnet to send an email from the zabbix server.
        Hi, I think i've set this up right (attached is an image of the user) to show the groups.
        • RPW
          • Oct 2008
          • 11
          Set a shell for the Zabbix Server user
          If the Zabbix Server is running with des user "zabbix" (ps aux | grep zabbix). This user must have a Shell defiend for send emails (vi /etc/passwd):
          zabbix:x:110:65534::/usr/local/sbin:/bin/bash
          • kristiaan_d
            • May 2009
            • 15
            *Answered*
            I managed to resolve this problem as it turned out to be an incorrectly configured action that was stopping emails being sent.
            I added a basic rule that just says when it finds a problem send an email and it worked.
