Help understanding Zabbix
  • sid
    • Jul 2006
    • 44
    I am using the latest version of Zabbix.
    What I am really confused about is, when do I have to change the "User-Defined Monitored Parameter" section of the config file. I am trying to pull system.cpu.intr stats for a windows server. Right now, it shows as NOT SUPPORTED. Do I have to change the config file with:
    PerfCounter = interrupts,"\Processor(0)\Interrupts/sec",60?
    I am really unsure about when and what I should add to a config file if I want to collect certain statistics.
    Where can I find documentation about this?
    Thanks,
    Sid
  • sid
    • Jul 2006
    • 44
    does anybod have two cents to throw in here?
    I'm a little desparate.
    • dantheman
      • May 2006
      • 209
      You only need to make changes to the config file if you need to pull a custom paramater that the zabbix agent does not support internally.
      • sid
        • Jul 2006
        • 44
        OK. I did that....then how do I change the front end to pull that data? I guess my question is what item do I have to add to the front-end?
        And would the key be what I put into the config file or would it be different?
        • jem313
          • Aug 2006
          for the front end, login as an admin, hit the items tab, find the template of the computer you want to add this to (prob windows_t), hit create item,
          Description: Whatever you want
          Type: Zabbix Agent
          Key: interrupts (this is what you named your custom perfcounter, keep them both lowercase)
          Type of information: Float
          Units: Make something up so it will show on the charts, like Ips (interrupts per second)
          Use multiplier: no
          Update interval (in sec): Your choice
          Keep history (in days): Your choice
          Keep trends (in days): Your choice
          Status: Monitored
          Store value: As is
          Applications:
          To test from the machine you want to monitor if your custom metric is working without configuring the server every time do this.
          Add it to the zabbix_agentd.conf
          Restart the service through the services tab in windows.
          Open the command prompt Start > run > cmd
          Find where you have the zabbixw32.exe
          Type: zabbixw32.exe test metricname (case sensitive)
          example: zabbixw32.exe test interrupts
          C:\>zabbixw32.exe test interrupts
          Using configuration file "C:\zabbix_agentd.conf"
          Configuration file OK
          [10-Aug-2006 13:11:24] *************** Log file opened ****************
          [10-Aug-2006 13:11:24] Collector thread initialized successfully
          interrupts [0.000000]
          • sid
            • Jul 2006
            • 44
            thanks for the help.
