Monitor File content with discovery
  • jerelev
    • Feb 2015
    • 15
    Hi
    I have a use case and it feels like Zabbix can help me do it, but i don't know to.
    I have N build agents on a server (windows but not sure it's important)
    First, i need to discover how many agents there are, then monitor the configuration file within the directory
    Let's say:
    C:\agent1
    C:\agent2
    C:\agentn
    I will need to monitor
    C:\agent1\conf\configuration.properties
    C:\agent2\conf\configuration.properties
    C:\agentn\conf\configuration.properties
    Then, i will create a trigger that raise an alert if the content of the file has no pattern1 or pattern2 or pattern3.
    Any advice?
    Thanks!
    Jeremie.
