SNMP fallback {item.value}
  • skipzoid
    • Jul 2019
    • 20
    Hello.
    Short question : how can I make :
    20:55:56 2019/07/29 enterprises.318.0.17 Normal "General event" 172.16.10.231 - enterprises.318.2.3.3.0:The batteries of the UPS need immediate replacement. on UPS Workshop;
    Be shown as The batteries of the UPS need immediate replacement. on UPS Workshop
    Long question:
    After following a number of guides I now have SNMP traps working and when a fallback trap is received it shows the long version above, all the received traps seem to show the IOD and then the actual textual information.
    Being a noop I'm still finding my feet and somewhat at a loss as to what to do now to get these translated into something shorter that easier to read.
    thanks,
  • Hamardaban
    • May 2019
    • 2714
    You can make a separate data item for enterprises.318.0.17 traps (like snmptrap["enterprises.318.0.17"]) and locate the desired string by preprocessing. and use them as trigger descriptions. Or a dependent data item with similar operation logic and trigger. For example regex "^.*The batteries of the UPS need immediate replacement\.(.*);$" and grop \1 .
    • skipzoid
      • Jul 2019
      • 20
      Hi, thanks for the reply. being a noob I've not followed what you said unfortunately. I'm using snmptt , I was hoping there was a way that it could lookup the short text explanation of the problem from the mibs and pass that to zabbix instead of the actual message being provided by the device.
      • Hamardaban
        • May 2019
        • 2714
        Using snmptt, you can format the trap message any way you want, using different variables. At http://snmptt.sourceforge.net/docs/snmptt.shtml go to FORMAT
        But there are predefined fields that will still be in zabbix message (20:55:56 2019/07/29 enterprises.318.0.17 Normal "General event" 172.16.10.231) according to documentation.
        Therefore, the option of converting strings on the server side was proposed
