In Zabbix version prior to 4.0, it was possible to select an unacknowledged trigger item and then check "selected and all other unacknowledged problems of related trigger" and all other unacknowledged instances of that same trigger would be acknowledged. So if a single event was triggered multiple times, you could acknowledge all of them at once.
I cannot find the same feature in 4.0 or 4.2. "Selected and all other problems of related triggers" seems to not work the same and only acknowledges the single instance and any other related trigger of that instance. I have several thousand instances of the same trigger I need to acknowledge and am having to do it page at a time. Is there some way to do all of these in one shot?
