I'd like to send a trap to different zabbix server with a trigger status via zabbix_sender with every trigger change. Firing a trigger sends properly an e-mail and doesn't bother to start a script at all.
Here are print screens with definition of this action:
Action:
Conditions:
Operations:
I've tried to execute this sctipt on both, zabbix agent (with running remote commands being enabled in agent config ) and zabbix server. I've granted rigths to zabbix user to use zabbix_sender. Host: Zabbix server (target of the action) is a local machine. Sending via zabbix sender data manually works ok.
I'm sure I'm missing something obvious. Thanks in advance for any help.
Action:
,Conditions:
,Operations:
.I've tried to execute this sctipt on both, zabbix agent (with running remote commands being enabled in agent config ) and zabbix server. I've granted rigths to zabbix user to use zabbix_sender. Host: Zabbix server (target of the action) is a local machine. Sending via zabbix sender data manually works ok.
