Hello all,
I have been looking for a solution. Here is my problem :
I want to perform provisioning on my different switches. For instance, I want to know when a port hasn't been used for 2 months (= to average 60 days).
I understand this could be done by using triggers, set to information state, but how do I configure the tiggrer ?
I want to set the trigger to the item ifOperStatus, for exemple, if the ifOperStatus is set to "0" (down) for 60 days, then the triggers return the information.
I understand also that I can do exactly the same while using the item ifInOctet or ifOutOctet, and compare the values for the same period. But, according to me, it would be easier to set the trigger to check if the boolean (1=up, 0=down) for 60 days.
Thank you for your help.
Drumspirit
Drumspirit
