Monitor items with dynamic key values
  • ryafro
    • Jul 2014
    Looking for assistance on monitoring a log file that has a date in the path/name, e.g.
    vfs.file.time[/some/path/to/log/file/log_yyyyMMdd.log,change]
    Where yyyyMMdd is the current date.
    What is the best-practices approach to this issue?
    Thanks in advance!
  • filipp.sudanov
    • May 2014
    • 137
    The values for yyyyMMdd should be definetely filled in on agent - if they were filled in on server, that might be delayed due to configuration synchronization.
    So, probably a UserParameter, that calls a script. See https://www.zabbix.com/documentation...userparameters
    • coreychristian
      • Jun 2012
      • 159
      Sorry misread the original post (need my caffeine) not sure if you can use regex or not on that particular item. You may need to write a script that checks the file time stamp, or play around to see if variables/regex work with that item.
      • ryafro
        • Jul 2014
        Thanks for the responses!
        I have 300+ log files I'd need to check in this manner. When I look at Zabbix documentation on external scripts, I see the following:
        "Do not overuse external checks! It can decrease performance of the Zabbix system a lot."
        What is considered overuse?
        • coreychristian
          • Jun 2012
          • 159
          External scripts are different then parameters.
          An external script is run from the zabbix server. A user parameter allows you to use a script locally on the zabbix client.
          • ryafro
            • Jul 2014
            Thank you for the clarification. I will check the documentation and give it a shot.
            Thanks for your help!
            • ryafro
              • Jul 2014
              Thank you! This seems to work!
              Here was my solution:
              zabbix_agentd.conf
              UserParameter=check_file_age[*],stat -c %Z $1/`date +%Y%m%d`/$2
              Testing:
              zabbix_get -s hostname -k check_file_age[/home/somepath/,somefile.txt]
              1407356359
