Please help!!
  • debora
    • Jan 2006
    • 75
    Please help!!
    I have a problem with Configuration-> IT SERVICES-> Add server details-> server xxx click add server and show this error:
    [Trigger added]
    SQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'on,0,off,99)' at line 1Query: insert into services (name,status,triggerid,algorithm,showsla,goodsla,s ortorder) values ('el servidor es inalcanzabble',0,12218,on,0,off,99)
    SQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '1,0)' at line 1
    Query: insert into services_links (servicedownid,serviceupid,soft) values (,1,0)
    Query: insert into services (name,status,triggerid,algorithm,showsla,goodsla,s ortorder) values ('prueba',0,12209,on,0,off,99)
  • amcorreia
    • Mar 2006
    • 73
    What version of zabbix you are running?
    • debora
      • Jan 2006
      • 75
      I have zabbix 1.1 in debian 3.1 (stable) and mysql 4.1.11
      • azilber
        • Apr 2005
        • 33
        [Trigger added]
        Make sure magic quotes are off in your php.ini.
        ; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
        magic_quotes_runtime = Off
        • debora
          • Jan 2006
          • 75
          Is off, look:
