Monitor CPU and RAM Xen Server
  • raphael.lage
    • Jul 2019
    • 9
    Good morning guys. I have a virtualized environment on Xen Server 7.4 and am having difficulty monitoring CPU and RAM of physical hosts. I found some templates on the internet, but none of them worked. Can anyone give a help ?? Thanks in advance.
  • Manishk
    • Apr 2019
    • 12
    Hello raphael.lage ,
    What procedure did you follow and which template you have used to monitor the CPU and RAM?
    • raphael.lage
      • Jul 2019
      • 9
      Hello Manishk One of the ones I tried to use was this https://share.zabbix.com/cat-app/clu...n-pyton-xenapi
      I also tried using one that monitors via SNMP, to no avail as well. Do you have any suggestions?
