Windows log file monitoring - recovery problem
  • alientm
    • Aug 2014
    • 51
    Log fragment:
    A response to the network message was received: 1814: 800
    No response to the network message (time-out)
    Zabbix agent: active
    Key: log[D:\jHost\log\jHost.log,time-out]
    Expression:
    {SERVER:log[D:\jHost\log\jHost.log,time-out].str(time-out)}=1 and {SERVER:log[D:\jHost\log\jHost.log,time-out].nodata(10m)}=0
    If zabbix finds the expression "time-out" in the log file, then since finding the expression, unfortunately, I have been reporting the problem all day and then OK, the problem and OK, and so until the next day when a new log file appears without the word "time-out".
  • alientm
    • Aug 2014
    • 51
    Is it possible that the problem is probably that the log (xml) file is read every time by zabbix from the first lines and each time finds the "time-out" that occurred earlier?
    • Hamardaban
      • May 2019
      • 2714
      Try use maxlines \ mode \ maxdelay option of log key.
      • alientm
        alientm commented
        i try
        log[D:\jHost\log\jHost.log,"time-out",,,skip,,]
        but zabbix still collects log data as if from the beginning of the jhost.log file.
    • Hamardaban
      • May 2019
      • 2714
      skip - only for the newly created data item. Then only new lines are processed. Just start with an empty file! :-)
      • alientm
        alientm commented
        OK, I understand, I will wait until tomorrow, the application creates a new log file with the same name every day (the old one is packed).
    • alientm
      • Aug 2014
      • 51
      However, it doesn't work as I would like.
      I forced 2 errors after 7 and 9 o'clock. After the error at 7 o'clock correctly zabbix turned off warning, but after the error at 9 o'clock continuous finds an error in the log file - although the error has not occurred since 9 o'clock.
