Monitoring screens display
  • novint
    • Jul 2019
    • 29
    Hello
    good afternon to everyone.
    i would like to show my manager at my workplace the new Zabbix server i installed and i made all of it quite cool,
    the system monitoring and capturing the data i want and need for our company's needs.
    the only problem is the way that screens presenting the data. it should work fine the way it is but its kinda annoying to have to tilt your head in order to read those headlines. is there anything to do about it? a way to change it?
    Click image for larger version  Name:	zabbix screen headlines.png Views:	2 Size:	46.2 KB ID:	384060
  • gofree
    • Dec 2017
    • 400
    try grafana zabbix integration
    • novint
      • Jul 2019
      • 29
      Originally posted by gofree
      Hello gofree..
      i've tried to follow the instructions in this link but im having hard time working it out.
      im using ubuntu bionic 18.04 as platfrom for Zabbix.
      can you please help me to sort how i implent this grafana to this system?
      • novint
        • Jul 2019
        • 29
        i have installed Grafana Server and also the alexanderzbonin-zabbix-app but it doesnt appear in the plugins in the web console
        • gofree
          • Dec 2017
          • 400
          • novint
            • Jul 2019
            • 29
            i followed those instructions and the terminal cli confirm the plugin is installed, but i cant see it in the web console
            • gofree
              • Dec 2017
              • 400
              not sure what you mean by web console
              • novint
                • Jul 2019
                • 29
                localhost:3000/plugins
                • gofree
                  • Dec 2017
                  • 400
                  just guessing wild - try to restart grafana server
                  • novint
                    • Jul 2019
                    • 29
                    i did it few times. it says that after any action i take in the terminal that regarding to the server.
                    • gofree
                      • Dec 2017
                      • 400
                      strange I just installed grafana on my test centos7, installed plugin, restarted grafana and its there - just needed to enable it and it works
                      [root@centos7 gofree]# grafana-cli plugins install alexanderzobnin-zabbix-app
                      installing alexanderzobnin-zabbix-app @ 3.10.4
                      from: https://grafana.com/api/plugins/alex....10.4/download
                      into: /var/lib/grafana/plugins
                      ✔ Installed alexanderzobnin-zabbix-app successfully
                      Restart grafana after installing plugins . <service grafana-server restart>
                      [root@centos7 gofree]# systemctl restart grafana-server
                      • novint
                        • Jul 2019
                        • 29
                        yes that's the indicatior i have in my terminal as well.
                        more of which
                        if i type in the terminal : grafana-cli plugins ls
                        it returns:
                        installed plugins:
                        yet still nothing in localhost:3000/plugins
                        • gofree
                          • Dec 2017
                          • 400
                          assuming that you installed latest version from official repository ( plugin + grafana on teh same server ) and it doesnt work I'd do 2 things:
                          1. uninstall everything, delete remaining files and try it again - check logs ( optioanlly try centos7 )
                          2. if point 1 doesnt work open an asuppor issue https://github.com/alexanderzobnin/g...-zabbix/issues - from the info youve provided its hard to tell
