Can you use variables as "required strings" in Web Scenarios?
  • kitkit201
    • Jan 2014
    • 9
    So i am creating a web scenario, that is pikcing up a string and holding it as a variable in step1. Then in step 2, it uses that string on another part of the site to make sure it exists.
    My Regex expresion in step 1 is
    {titlename}=regex:title="([a-zA-Z0-9,: -]+)
    However, i think the "required string" step in step 2, is taken the litteral {titlename} and not interpretting it as a MACRO name.
    How can I make it interpret the macro instead of the literal?
    Kit
  • jan.garaj
    • Jan 2010
    • 506
    You can use only MACRO in Required string (function substitute_simple_macros).
    VARIABLE can be used only in Post and URL (function http_substitute_variables).
    Source: source code https://www.zabbix.org/websvn/wsvn/z...ler/httptest.c
