Help - nodata() function
  • drumspirit
    • Mar 2014
    • 13
    I know that there are many topics about this function, but still, I cannot find any solution to solve my problem.
    I have a trigger that is {mytemplate:my.value-in.nodata(300)}=1 & {mytemplate:my.value-out.nodata(300)}=1
    I applied this trigger to two equipements :
    - 1 that receives absolutely no data
    - 1 1 that receives data permanently
    The trigger set this way, it never fires. I can define any parameter that I want (nodata(1440m), nodata(84600), with an "s" or without) the trigger never fires. Even "days" or "week" parameters don't even do the difference
    If I set the trigger function to :
    {mytemplate:my.value-in.nodata(300)}=0 & {mytemplate:value-out.nodata(300)}=0
    Then it fires in the very first 30 seconds or 60 seconds (I cannot tell exactly).
    I have also tried other function, based on a period a passed time (such as "count", "max", etc.), with exactly no difference. It seems like Zabbix is not considering the period parameter.
    Is there any one who can help me please ? I'm desperate
    For info : I'm using Zabbix 2.2.1
    Thank you.
    Nds
  • drumspirit
    • Mar 2014
    • 13
    bump !
    Is there anyone who can help please ?
    Thank you !
    • drumspirit
      • Mar 2014
      • 13
      Thank you for the help of the community, I really appreciate
      Found the answer and the good parameters to set even though the documentation suffers a lack of explanation.
      I still don't understand how people can make a simple trigger value.nodata(300)=1 work
