Hi to all,
I have more than 6500 hosts and if someone clicks ALL on "Latest data" everything goes to hell, load on server is 20 from 1.
Solution is to disable option "all" in dropdown first menu, but than I can't view all triggers.
Does anyone know how can I edit tr_status.php so that I can view all triggers with "Dropdown first entry: NONE" enabled? Selet all doesn't event have to be on dropdown list, I can use custom url?
Thank you in advance
Regards
Regards
