zabbix_get not installed inspite of zabbix-server-mysql package is installed
  • Pradish
    • Jul 2017
    • 9
    When i try to execute zabbix_get i get error that it is not installed.
    xxxxx@Zxxxx2:~$ zabbix_get
    The program 'zabbix_get' can be found in the following packages:
    * zabbix-proxy-mysql
    * zabbix-proxy-pgsql
    * zabbix-proxy-sqlite3
    * zabbix-server-mysql
    * zabbix-server-pgsql
    Try: sudo apt install <selected package>
    However I zabbix-server-mysql package is installed.
    xxxx@Zxx2:~$ sudo dpkg -l | grep -i zabbix
    iF zabbix-agent 1:3.4.15-1+xenial amd64 Zabbix network monitoring solution - agent
    ii zabbix-frontend-php 1:3.4.15-1+xenial all Zabbix network monitoring solution - PHP front-end
    ii zabbix-release 3.4-1+xenial all Zabbix official repository configuration
    ii zabbix-server-mysql 1:3.4.15-1+xenial amd64 Zabbix network monitoring solution - server (
    How can i get zabbix_get installed?
  • Markku
    • Sep 2018
    • 1784
    sudo apt install zabbix-get
    I have no idea where the ”can be found in” list is coming from.
    Markku
