commnad to stop zabbix agent
  • paragpalkhe
    • Aug 2019
    I use following command to start the zabbix agent
    /opt/app/zabbix_agent/sbin/zabbix_agentd
    What is the command to stop the agent gracefully using the zabbix command ?
    (the zabbix agent is owned by application owner so systemctl start / stop is no good)
    Please let me know how do you deal with this.
  • Markku
    • Sep 2018
    • 1781
    Hi, you can kill it. This is from an install done using Zabbix repo:
    $ [B]systemctl status zabbix-agent | grep loaded[/B]
    Loaded: loaded (/lib/systemd/system/zabbix-agent.service; enabled; vendor preset: enabled)
    $ [B]cat /lib/systemd/system/zabbix-agent.service[/B]
    [Unit]
    Description=Zabbix Agent
    After=syslog.target
    After=network.target
    [Service]
    Environment="CONFFILE=/etc/zabbix/zabbix_agentd.conf"
    EnvironmentFile=-/etc/default/zabbix-agent
    Type=forking
    Restart=on-failure
    PIDFile=/run/zabbix/zabbix_agentd.pid
    KillMode=control-group
    ExecStart=/usr/sbin/zabbix_agentd -c $CONFFILE
    [B]ExecStop=/bin/kill -SIGTERM $MAINPID[/B]
    RestartSec=10s
    [Install]
    WantedBy=multi-user.target
    One way is using "killall zabbix_agentd".
    Markku
    • paragpalkhe
      • Aug 2019
      Thanks for your reply. I will continue to kill the processes using kill command however just wanted to know if there is any better way to stop them gracefully other than systemctl stop. Thanks again for your help.
