Rails web monitoring and authenticity_token
  • arndtt
    • Dec 2013
    • 10
    I thought it's better to start a new thread out of https://www.zabbix.com/forum/showthread.php?t=10661
    I would like to monitor a Rails application that uses a simple authentication with username and password and the common Rails security feature authenticity_token which is a hidden field and contains a hash that is generated automatically with every website visit.
    I managed to extract the token with a relative new feature on our Zabbix 2.2.5 server system:
    Join the friendly and open Zabbix community on our forums and social media platforms.
    In several previous articles in the Zabbix 2.2 series we already discussed several improvements for web monitoring – the ability to template it, customise the amount of retries and the ability to specify an HTTP proxy on the scenario level. There’s more – in 2.2 it will also be possible to parse content from a […]
    But sometimes (not everytime) the login step in the web scenario fails if there are special characters in the hash....
    my variable definition:
    {token}=regex:input name="authenticity_token" type="hidden" value="(.{44})"
    my post:
    authenticity_token={token}
    Rails Log:
    Started POST "/login" for x.x.x.x at 2014-08-13 10:01:19 +0200
    Processing by AccountController#login as */*
      Parameters: {"utf8"=>"✓", "back_url"=>"https://bla.bla.bla/", "authenticity_token"=>"DczPoEpy0I/Aojo9AF7W0LnqW2yt1 pmVm2nbIzdnQc=", "username"=>"zabbix", "password"=>"[FILTERED]", "login"=>"Anmelden »"}
    WARNING: Can't verify CSRF token authenticity
      Rendered common/error.html.erb within layouts/base (0.3ms)
      Rendered plugins/redmine_banner/app/views/banner/_project_body_bottom.html.erb (0.0ms)
    Filter chain halted as :verify_authenticity_token rendered or redirected
    Completed 422 Unprocessable Entity in 10.7ms (Views: 9.1ms | ActiveRecord: 0.7ms)
    => Can you see the whitespace in the authenticity_token in the logfile ? I think but I'm not sure the website is giving the token hash in a format that can not be stored in a variable. Might be a special character like % or has something to to with url encoding...
    How do I get out of this ? I'm not a regex expert but I think it's correct for my goal.
  • richlv
    • Oct 2005
    • 3112
    you are taking 44 characters, and "DczPoEpy0I/Aojo9AF7W0LnqW2yt1 pmVm2nbIzdnQc=" is 44 chars long.
    what do you mean by "special characters" - can you post an exact example that fails ?
    • arndtt
      • Dec 2013
      • 10
      Thanks for your reply. The example I already posted is the one that is failing. Sorry for making that not clear enough.
      If you take a look at "DczPoEpy0I/Aojo9AF7W0LnqW2yt1 pmVm2nbIzdnQc=" you can see that between "1" and the "p" is a whitespace. I believe this is the problem here. No whitespaces within an authenticity_token are allowed...
      My guess what happens here is the Rails authenticity_token that is required is actually "DczPoEpy0I/Aojo9AF7W0LnqW2yt1%pmVm2nbIzdnQc=" but my automated Zabbix login posts "DczPoEpy0I/Aojo9AF7W0LnqW2yt1 pmVm2nbIzdnQc="
      I don't know why Zabbix or my regex is doing this but a possible reason could be Zabbix doesn't allow storing URL encoded strings in a variable if I interpret https://www.zabbix.com/documentation...web_monitoring in the right way. And as you know the "%" is a central charactar in the area of URL-encoding.
      • richlv
        • Oct 2005
        • 3112
        no, i meant the input case that results in the failure - are you sure it's "DczPoEpy0I/Aojo9AF7W0LnqW2yt1%pmVm2nbIzdnQc=" or is that just a guess ?
        can you trace a failing case and see what exactly is contained in the page that makes it all fail ?
        • arndtt
          • Dec 2013
          • 10
          Right now I'm only guessing. Give me some time if I'm able to debug this...
          • richlv
            • Oct 2005
            • 3112
            ok, let's see the input that results in this - until then it's unclear what the problem might be
            • arndtt
              • Dec 2013
              • 10
              O.k. I'v edited the relevant ruby function according to this post:
              http://stackoverflow.com/questions/1...ifferent-times
              This results in the following log files (2 authentication attempts are shown):
              Parameters: {"utf8"=>"✓", "back_url"=>"https://bla.bla.bla/", "authenticity_token"=>"fSdoIF/Aj380peiu1RL2H QfESk/8/55Jnaf3OxL0sA=", "username"=>"zabbix", "password"=>"[FILTERED]", "login"=>"Anmelden »"}
              printing info from `verified_request?` ...
              request_forgery_protection_token = authenticity_token
              form_authenticity_token = fSdoIF/Aj380peiu1RL2H+QfESk/8/55Jnaf3OxL0sA=
              params[request_forgery_protection_token] = fSdoIF/Aj380peiu1RL2H QfESk/8/55Jnaf3OxL0sA=
              request.headers['X-CSRF-Token'] =
              Parameters: {"utf8"=>"✓", "back_url"=>"https://bla.bla.bla/", "authenticity_token"=>"jgExECYdNvfS0N8c jnaxAfTW7kS83JlmZapnwseexw=", "username"=>"zabbix", "password"=>"[FILTERED]", "login"=>"Anmelden »"}
              	form_authenticity_token = jgExECYdNvfS0N8c+jnaxAfTW7kS83JlmZapnwseexw=
              	params[request_forgery_protection_token] = jgExECYdNvfS0N8c jnaxAfTW7kS83JlmZapnwseexw=
              => The '+' character is filtered out by my regex definition...
              • richlv
                • Oct 2005
                • 3112
                according to wiper, this is likely to be caused by server not url-encoding sent data - which would be https://support.zabbix.com/browse/ZBXNEXT-2074
                • fserve
                  • Jan 2015
                  i have a similar problem, but when i tried what you did, i got another problem.
                  i just can't use any kind of regex in my zabbix.
                  the variables
                  {username}=admin
                  {password}=pass
                  {utf8}=✓
                  {login}=Sign in »
                  give to me:
                  Error: error in scenario variables "{username}=admin {password}=pass {token}=regex:input name="authenticity_token" type="hidden" value="(.{44})" {utf8}=✓ {login}=Sign in»": cannot extract the value of "{token}" from response
