Issue with Remote SSH Command in Action Configuration
  • bullmike
    • Jul 2014
    • 10
    I've created an action to accompany a trigger that should log in via SSH to a router and ping a few IP to bring back up a VPN tunnel to a remote location. As a test I modified the host with an invalid IP address to trigger the action.
    In the event details I get the following error message for the SSH connection:
    === Cannot establish SSH session: Unable to exchange encryption keys ===
    From the zabbix server - v2.2.1 on Centos 6.5 via Yum EPEL installation - I can SSH to the host without issue and added the RSA key to known_hosts using the username/password as specified in the the configuration for the Remote SSH command.
    I turned on Debug logging but it doesn't seem to provide any information that may be useful in troubleshooting the issue.
    Any ideas?
  • filipp.sudanov
    • May 2014
    • 137
    1. Go through the docs to check if nothing is missed - https://www.zabbix.com/documentation...pes/ssh_checks
    2. Zabbix server is running under "zabbix" user. That user has it's own known_hosts. Try something like "su - zabbix" - not sure about exact command for CentOS and check if you can connect to you server from zabbix user. You man need to alter /etc/passwd and put a proper command intepreter for zabbix user.
    • bullmike
      • Jul 2014
      • 10
      Turns out the device that I was trying to SSH into only supported SSH1 no SSH2. As far as I know Zabbix requires SSH2 to function correctly.
      A good way to test if you end device is compatible with SSH2 is to login to your zabbix server and issue a 'ssh -2 user@ip' you will get an error similar to the following if your device doesn't support (or doesnt have enabled ) SSH2.
      Protocol major versions differ: 2 vs. 1"
