collect data from mongo to zabbix
  • sirmosi
    • Aug 2014
    hello everyone
    this is the first time that i install zabbix on debian Dist, so after configuration the zabbix i wanna having access and monitor my mongodb on another server.
    so i follow this : https://code.google.com/p/mikoomi/wiki/03
    but still in zabbix doesn't access to data and when i'm looking to the graphs provide by template it's empty and show no data
    i change mikoomi_mongodb_plugin.sh,mikoomi_mongodb_plugin.p hp,and other configuration in zabbix gui
    if needed i can show my configuration, could any one help me ???
  • sirmosi
    • Aug 2014
    any help ,,,,
    if you need more info tell me ????!!!!!
    plz i need help
    • karmukis
      • Aug 2014
      • 37
      Hi, I know is been a while since you asked for help but, this help me a lot, even doe we ended up not using it because it requires PHP, and we don'twant garbage install in the MONGODB servers if not really needed so.... not using mikoomi plugin after all, but if you check the READ ME, you'll see there's more detail info that in the orginal post, and the files have been update recently.
      Hope this helps you.
      best of lucks!!
      karina costa
      Forked from the mikoomi-templates project from here: https://code.google.com/p/mikoomi but only containing the MongoDB Zabbix Plugin - nightw/mikoomi-zabbix-mongodb-monitoring
