I have problam with starting up zabbix. After execute systemctl status zabbix-server im watching samthig like that:
● zabbix-server.service - Zabbix Server
Loaded: loaded (/lib/systemd/system/zabbix-server.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2019-09-04 11:36:54 UTC; 263ms ago
Process: 6900 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
Main PID: 6913 (code=exited, status=1/FAILURE)
wrz 04 11:36:54 monitorowanie systemd[1]: zabbix-server.service: Main process exited, code=exited, status=1/FAILURE
wrz 04 11:36:54 monitorowanie systemd[1]: zabbix-server.service: Failed with result 'exit-code'.
in var/log/zabbix/zabbix-server.log i finded something like that:
7196:20190904:113849.975 Starting Zabbix Server. Zabbix 4.2.6 (revision d3bb18bbc4).
7196:20190904:113849.975 ****** Enabled features ******
7196:20190904:113849.975 SNMP monitoring: YES
7196:20190904:113849.975 IPMI monitoring: YES
7196:20190904:113849.975 Web monitoring: YES
7196:20190904:113849.975 VMware monitoring: YES
7196:20190904:113849.975 SMTP authentication: YES
7196:20190904:113849.975 Jabber notifications: NO
7196:20190904:113849.975 Ez Texting notifications: YES
7196:20190904:113849.975 ODBC: YES
7196:20190904:113849.975 SSH2 support: YES
7196:20190904:113849.975 IPv6 support: YES
7196:20190904:113849.975 TLS support: YES
7196:20190904:113849.975 ******************************
7196:20190904:113849.976 using configuration file: /etc/zabbix/zabbix_server.conf
7196:20190904:113849.989 current database version (mandatory/optional): 04020000/04020001
7196:20190904:113849.989 required mandatory version: 04020000
7196:20190904:113850.381 __mem_malloc: skipped 10 asked 108424 skip_min 368 skip_max 32640
7196:20190904:113850.382 [file:dbconfig.c,line:94] __zbx_mem_realloc(): out of memory (requested 108424 bytes)
7196:20190904:113850.382 [file:dbconfig.c,line:94] __zbx_mem_realloc(): please increase CacheSize configuration parameter
7196:20190904:113850.382 === memory statistics for configuration cache ===
7196:20190904:113850.382 free chunks of size 24 bytes: 89
7196:20190904:113850.382 free chunks of size 32 bytes: 78
7196:20190904:113850.382 free chunks of size 40 bytes: 3
7196:20190904:113850.382 free chunks of size 48 bytes: 3
7196:20190904:113850.382 free chunks of size 56 bytes: 4
7196:20190904:113850.382 free chunks of size >= 256 bytes: 10
7196:20190904:113850.382 min chunk size: 24 bytes
7196:20190904:113850.382 max chunk size: 32640 bytes
7196:20190904:113850.382 memory of total size 8388232 bytes fragmented into 69596 chunks
7196:20190904:113850.382 of those, 103048 bytes are in 187 free chunks
7196:20190904:113850.382 of those, 7171664 bytes are in 69409 used chunks
7196:20190904:113850.382 ================================
7196:20190904:113850.382 === Backtrace: ===
7196:20190904:113850.383 13: /usr/sbin/zabbix_server(zbx_backtrace+0x4e) [0x55c6691fc12b]
7196:20190904:113850.383 12: /usr/sbin/zabbix_server(__zbx_mem_realloc+0x160) [0x55c6691f7506]
7196:20190904:113850.383 11: /usr/sbin/zabbix_server(+0x17f671) [0x55c6691be671]
7196:20190904:113850.383 10: /usr/sbin/zabbix_server(zbx_hashset_reserve+0xc1) [0x55c669201504]
7196:20190904:113850.383 9: /usr/sbin/zabbix_server(zbx_hashset_insert_ext+0xef) [0x55c66920177c]
7196:20190904:113850.383 8: /usr/sbin/zabbix_server(zbx_hashset_insert+0x2d) [0x55c66920168b]
7196:20190904:113850.383 7: /usr/sbin/zabbix_server(DCfind_id+0x9b) [0x55c6691bf034]
7196:20190904:113850.383 6: /usr/sbin/zabbix_server(+0x18ae76) [0x55c6691c9e76]
7196:20190904:113850.383 5: /usr/sbin/zabbix_server(DCsync_configuration+0xb6d) [0x55c6691cb64b]
7196:20190904:113850.383 4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x72e) [0x55c66907ec23]
7196:20190904:113850.383 3: /usr/sbin/zabbix_server(daemon_start+0x2f0) [0x55c6691fb854]
7196:20190904:113850.384 2: /usr/sbin/zabbix_server(main+0x305) [0x55c66907e4df]
7196:20190904:113850.384 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7ff151a00b97]
7196:20190904:113850.384 0: /usr/sbin/zabbix_server(_start+0x2a) [0x55c66907d58a]
7242:20190904:113900.483 Starting Zabbix Server. Zabbix 4.2.6 (revision d3bb18bbc4).
7242:20190904:113900.484 ****** Enabled features ******
7242:20190904:113900.484 SNMP monitoring: YES
7242:20190904:113900.484 IPMI monitoring: YES
7242:20190904:113900.484 Web monitoring: YES
7242:20190904:113900.484 VMware monitoring: YES
7242:20190904:113900.484 SMTP authentication: YES
7242:20190904:113900.484 Jabber notifications: NO
7242:20190904:113900.484 Ez Texting notifications: YES
7242:20190904:113900.485 ODBC: YES
7242:20190904:113900.485 SSH2 support: YES
7242:20190904:113900.485 IPv6 support: YES
7242:20190904:113900.485 TLS support: YES
7242:20190904:113900.485 ******************************
7242:20190904:113900.486 using configuration file: /etc/zabbix/zabbix_server.conf
7242:20190904:113900.497 current database version (mandatory/optional): 04020000/04020001
7242:20190904:113900.498 required mandatory version: 04020000
7242:20190904:113900.883 __mem_malloc: skipped 10 asked 108424 skip_min 368 skip_max 32640
7242:20190904:113900.883 [file:dbconfig.c,line:94] __zbx_mem_realloc(): out of memory (requested 108424 bytes)
7242:20190904:113900.883 [file:dbconfig.c,line:94] __zbx_mem_realloc(): please increase CacheSize configuration parameter
7242:20190904:113900.883 === memory statistics for configuration cache ===
7242:20190904:113900.883 free chunks of size 24 bytes: 89
7242:20190904:113900.883 free chunks of size 32 bytes: 78
7242:20190904:113900.884 free chunks of size 40 bytes: 3
7242:20190904:113900.884 free chunks of size 48 bytes: 3
7242:20190904:113900.884 free chunks of size 56 bytes: 4
7242:20190904:113900.884 free chunks of size >= 256 bytes: 10
7242:20190904:113900.884 min chunk size: 24 bytes
7242:20190904:113900.884 max chunk size: 32640 bytes
7242:20190904:113900.884 memory of total size 8388232 bytes fragmented into 69596 chunks
7242:20190904:113900.884 of those, 103048 bytes are in 187 free chunks
7242:20190904:113900.884 of those, 7171664 bytes are in 69409 used chunks
7242:20190904:113900.884 ================================
7242:20190904:113900.884 === Backtrace: ===
7242:20190904:113900.885 13: /usr/sbin/zabbix_server(zbx_backtrace+0x4e) [0x5599ae2f412b]
7242:20190904:113900.885 12: /usr/sbin/zabbix_server(__zbx_mem_realloc+0x160) [0x5599ae2ef506]
7242:20190904:113900.885 11: /usr/sbin/zabbix_server(+0x17f671) [0x5599ae2b6671]
7242:20190904:113900.885 10: /usr/sbin/zabbix_server(zbx_hashset_reserve+0xc1) [0x5599ae2f9504]
7242:20190904:113900.885 9: /usr/sbin/zabbix_server(zbx_hashset_insert_ext+0xef) [0x5599ae2f977c]
7242:20190904:113900.885 8: /usr/sbin/zabbix_server(zbx_hashset_insert+0x2d) [0x5599ae2f968b]
7242:20190904:113900.885 7: /usr/sbin/zabbix_server(DCfind_id+0x9b) [0x5599ae2b7034]
7242:20190904:113900.885 6: /usr/sbin/zabbix_server(+0x18ae76) [0x5599ae2c1e76]
7242:20190904:113900.885 5: /usr/sbin/zabbix_server(DCsync_configuration+0xb6d) [0x5599ae2c364b]
7242:20190904:113900.885 4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x72e) [0x5599ae176c23]
7242:20190904:113900.885 3: /usr/sbin/zabbix_server(daemon_start+0x2f0) [0x5599ae2f3854]
7242:20190904:113900.885 2: /usr/sbin/zabbix_server(main+0x305) [0x5599ae1764df]
7242:20190904:113900.885 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f5dc9e27b97]
7242:20190904:113900.885 0: /usr/sbin/zabbix_server(_start+0x2a) [0x5599ae17558a]
why zabbix not starting ?
