system.run ( ping ) is not running
  • mbuyukkarakas
    • Aug 2014
    • 49
    Hello all,
    I would like to use zabbix agent system.run function to ping or curl some external addresses.
    like : zabbix_get -s 10.8.7.100 -p 10050 -k 'system.run[ping www.cnn.com]' or zabbix_get -s 10.8.9.143 -p 10050 -k 'system.run[curl www.cnn.com 80]'
    zabbix_get -s 10.8.7.100 -p 10050 -k 'system.run[ping cnn.com]'
    ZBX_NOTSUPPORTED: Timeout while executing a shell script.
    First, system.run[ping] is never running. Neither at Linux or Windows.
    Second, system.run[curl] is ok at Linux. But I couldnt found similar utiliy for Windows.
    I changed timeout value to the limit but it's still the same problem.
    Is it poss
    I believe its a usefull feature for measuring some connectivity problems. Anybody can help to solve this please ?
    Thank you.
    Mehmet
  • Atsushi
    • Aug 2013
    • 2028
    If you use system.run[] to ping on Linux, try specifying the number of times. If you do not specify the number of times, the ping command will continue to check many times.
    ex.
    zabbix_get -s 10.8.7.100 -p 10050 -k 'system.run[ping -c 2 cnn.com]'
    • mbuyukkarakas
      mbuyukkarakas commented
      Thank you Atsushi. Actually this is not what I want to achive. The problem is that Zabbix agent is never running this command for network related commands at Windows. Maybe this is a basic path problem or something else. I dont know yet.
