We make use of the zabbix check for 'int.if.status[eth0]' which runs the following command on the zabbix_agent host (according to the logs):
This seems to be incompatible with the version of ifconfig on some recent distros including Amazon Linux 2 where the ouput of ifconfig would not be matched by the grep pattern:
Is there some way by which I can modify this command so that it is compliant with the relevant ifconfig version that I have available on this distro?
Many thanks
David
EXECUTE_STR() command:'/sbin/ifconfig eth0 | /bin/grep -c " UP "' len:1 cmd_result:'0'
ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 9001
inet 10.37.3.119 netmask 255.255.255.128 broadcast 10.37.3.127
inet6 fe80::4f7:aeff:feaa:bfd4 prefixlen 64 scopeid 0x20<link>
ether 06:f7:ae:aa:bf:d4 txqueuelen 1000 (Ethernet)
RX packets 4932372 bytes 5383757478 (5.0 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 4869380 bytes 3945431884 (3.6 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Many thanks
David
