Agent log option not present
  • warp10
    • Apr 2019
    • 39
    Hi All,
    Could you tell me why I've not the option "log" in the select field Type of information when iI create the ITEM, it's ok on the zabbix server but not on the other zabbix-agent machine ?
    Thanks a lot
  • steve.destivelle
    • Feb 2017
    • 304
    Hi Warp,
    could you provide a screenshot ?
    Regards,
    Steve
    "Estimez la taille de votre base de données Zabbix: http://tools.izi-it.io
    "Rejoignez le ZABBIX Discord francophone https://discordapp.com/invite/hvauXEQ"
    "izi-it.io / ZABBIX Certified Trainer / ZABBIX French Evangelist"
    • warp10
      • Apr 2019
      • 39
      Just an breaking IP Floating , problem solved
