Hi Every one
i am facing issue in monitoring website.
I am using Zabbix 4.2.4 on Centos. I have created a Host and web senario. i want to get the 200Ok response and required string should be "Login".
i am getting the 200 Ok response , but for the required string it always say that "Step "LH OPA PROD_DECP Login" [1 of 1] failed: required pattern "Login" was not found on (website address).
My website takes a little bit time around 15 to 20 sec to load completedly.
Note: Agent : selected in the Host configuration is Chromium:installed on my Linux system. Previously i used this configuration with agent : Zabbix and website was not reachable and it was giving error:405., but now it is reacheable with 200 OK , but string is not findable.
I wanted , zabbix should check for required string after the page is fully loaded. I am not able to achive this thing by increasing time out time.
It is requested to please help.
