login api with http authentificate
  • aoc
    • Aug 2014
    hi,
    i have a problem that i can't resolve since few days.
    I try to connect my zabbix with api in http connection.
    It's work fine with internal but have error with http.
    #!/usr/bin/env python
    import urllib2
    import json
    def authenticate(url, username, password):
    values = {'jsonrpc': '2.0',
    'method': 'user.authenticate',
    'params': {
    'user': username,
    'password': password,
    'id': '0'
    data = json.dumps(values)
    req = urllib2.Request(url, data, {'Content-Type': 'application/json-rpc'})
    response = urllib2.urlopen(req, data)
    output = json.loads(response.read())
    print output
    try:
    message = output['result']
    except:
    message = output['error']['data']
    print message
    quit()
    return output['result']
    def main():
    url = 'http://localhost/zabbix/api_jsonrpc.php'
    username = "admin"
    password = "zabbix"
    auth = authenticate(url,username,password)
    if __name__ == '__main__':
    main()
    Cannot login.
    Can anyone have an idea?
  • JFontes
    • Jul 2012
    • 36
    Originally posted by aoc
    hi,
    Cannot login.
    Have your zabbix installed in the correct path? "url = 'http://localhost/zabbix/api_jsonrpc.php'"
    You need change this part:
    'user': username,
    'id': '0'
    your username, your passwd and id 1.
    • aoc
      • Aug 2014
      thanks for your repply.
      I have the username and password already defined from main.
      So i don't understand.
      Any one have an idea?
