Map URL target
  • dabbelju
    • Sep 2019
    Map URL target
    is it in Zabbix 4 somehow possible to open a URL which is added to map (either via the map properties or the map element) in a new tab or window and if yes how?
    I did search the web but found only possibilities to do it in Zabbix 2.x or 3.x. Of course it would be fantastic to have an option where to open the link in the mentioned places. It would not really help to have all URLs open in a new window or tab because tehere are for sure URLs which navigate "inside" Zabbix.
    I am looking forward to your feedback.
    thanks and best regards
    Dabbelju
  • dabbelju
    • Sep 2019
    Move hopefully in the right place...
    • dabbelju
      • Sep 2019
      Hi splitek,
      of course you are right. My Admins could also use a right click and something like "open in new tab" or "open in new window". I am asking this question to make it more easy for people.
      Would just be "nice".
      Dabbelju
      • Guntis
        • Mar 2019
        • 18
        Hi, I have created a patch based on the 2.x/3.x code I also found. This has been Tested on Zabbix 5.2, hopefully will work on 4.x as well
        HTML Code:
        diff --git a/usr/share/zabbix/js/menupopup.js.original b/usr/share/zabbix/js/menupopup.js
        index af31a0b..5c20a28 100644
        --- a/usr/share/zabbix/js/menupopup.js.original
        +++ b/usr/share/zabbix/js/menupopup.js
        @@ -250,6 +250,16 @@ function getMenuPopupHost(options, trigger_elmnt) {
        label: t('URLs'),
        items: options.urls
        + for (var key in options.urls) {
        + options.urls[key].clickCallback = function(url) {
        + return function(e) {
        + window.open(url, '_blank');
        + cancelEvent(e);
        + jQuery(this).closest('.menu-popup').hide();
        + }(options.urls[key].url);
        // scripts
        Zabbix 5.2 patch to open Map URLs in blank page. GitHub Gist: instantly share code, notes, and snippets.
