I'm having problem with zabbix-server under Centos7. systemd flag the service as "failed" Repeated restart of server process
/var/log/message :
/var/log/zabbix/zabbix_server.log:
/usr/lib/systemd/system/zabbix-server.service:
[CODE]Server-108 ~: cat /usr/lib/systemd/system/zabbix-server.service
[Unit]
Description=Zabbix Server
After=syslog.target
After=network.target
[Service]
Environment="CONFFILE=/etc/zabbix/zabbix_server.conf"
EnvironmentFile=-/etc/sysconfig/zabbix-server
Type=forking
Restart=on-failure
PIDFile=/run/zabbix/zabbix_server.pid
KillMode=control-group
ExecStart=/usr/sbin/zabbix_server -c $CONFFILE
ExecStop=/bin/kill -SIGTERM $MAINPID
RestartSec=10s
TimeoutSec=0
[Install]
WantedBy=multi-user.target
[CODE]
/etc/zabbix/zabbix_server.conf:
I would appreciate it if someone could help me
Server-108 ~: systemctl status zabbix-server.service -l
● zabbix-server.service - Zabbix Server
Loaded: loaded (/usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
Active: active (running) since 六 2019-09-14 01:10:56 CST; 1s ago
Process: 29475 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
Process: 29490 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
Main PID: 29492 (zabbix_server)
CGroup: /system.slice/zabbix-server.service
├─29492 /usr/sbin/zabbix_server -c /etc/zabbix/zabbix_server.conf
├─29493 /usr/sbin/zabbix_server: configuration syncer [waiting 60 sec for processes
├─29494 /usr/sbin/zabbix_server: housekeeper [startup idle for 30 minutes
├─29495 /usr/sbin/zabbix_server: timer #1 [updated 0 hosts, suppressed 0 events in 0.000996 sec, idle 59 sec
├─29496 /usr/sbin/zabbix_server: http poller #1 [got 0 values in 0.000299 sec, idle 5 sec
├─29497 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000278 sec, idle 60 sec
├─29498 /usr/sbin/zabbix_server: discoverer #2 [processed 0 rules in 0.000274 sec, idle 60 sec
├─29499 /usr/sbin/zabbix_server: discoverer #3 [processed 0 rules in 0.000262 sec, idle 60 sec
├─29500 /usr/sbin/zabbix_server: discoverer #4 [processed 0 rules in 0.000257 sec, idle 60 sec
├─29501 /usr/sbin/zabbix_server: discoverer #5 [processed 0 rules in 0.000270 sec, idle 60 sec
├─29502 /usr/sbin/zabbix_server: discoverer #6 [processed 0 rules in 0.000245 sec, idle 60 sec
├─29503 /usr/sbin/zabbix_server: discoverer #7 [processed 0 rules in 0.000291 sec, idle 60 sec
├─29504 /usr/sbin/zabbix_server: discoverer #8 [processed 0 rules in 0.094427 sec, idle 60 sec
├─29505 /usr/sbin/zabbix_server: discoverer #9 [processed 0 rules in 0.000223 sec, idle 60 sec
├─29506 /usr/sbin/zabbix_server: discoverer #10 [processed 0 rules in 0.000266 sec, idle 60 sec
├─29507 /usr/sbin/zabbix_server: history syncer #1 [processed 0 values, 0 triggers in 0.000018 sec, idle 1 sec
├─29508 /usr/sbin/zabbix_server: history syncer #2 [processed 0 values, 0 triggers in 0.000015 sec, idle 1 sec
├─29509 /usr/sbin/zabbix_server: history syncer #3 [processed 0 values, 0 triggers in 0.000012 sec, idle 1 sec
├─29510 /usr/sbin/zabbix_server: history syncer #4 [processed 0 values, 0 triggers in 0.000012 sec, idle 1 sec
├─29511 /usr/sbin/zabbix_server: escalator #1 [processed 0 escalations in 0.000485 sec, idle 3 sec
├─29512 /usr/sbin/zabbix_server: proxy poller #1 [exchanged data with 0 proxies in 0.000072 sec, idle 5 sec
├─29513 /usr/sbin/zabbix_server: self-monitoring [processed data in 0.000015 sec, idle 1 sec
├─29514 /usr/sbin/zabbix_server: task manager [started, idle 4 sec
└─29652 /usr/sbin/zabbix_server: preprocessing worker #3 started
9月 14 01:10:56 Server-108 systemd[1]: Stopped Zabbix Server.
9月 14 01:10:56 Server-108 systemd[1]: Starting Zabbix Server...
9月 14 01:10:56 Server-108 systemd[1]: zabbix-server.service: Supervising process 29492 which is not our child. We'll most likely not notice when it exits.
9月 14 01:10:56 Server-108 systemd[1]: Started Zabbix Server.
/var/log/message :
Sep 14 01:09:26 Server-108 systemd: Stopped Zabbix Server. Sep 14 01:09:26 Server-108 systemd: Starting Zabbix Server... Sep 14 01:09:26 Server-108 systemd: zabbix-server.service: Supervising process 28975 which is not our child. We'll most likely not notice when it exits. Sep 14 01:09:26 Server-108 systemd: Started Zabbix Server. Sep 14 01:09:46 Server-108 kill: 用法: Sep 14 01:09:46 Server-108 kill: kill [选项] <pid|名称> [...] Sep 14 01:09:46 Server-108 kill: 选项: Sep 14 01:09:46 Server-108 kill: -a, --all 不限于只对和当前进程的用户 id 相同的进程进行 Sep 14 01:09:46 Server-108 kill: 名称-进程id 转换 Sep 14 01:09:46 Server-108 kill: -s, --signal <信号> 发送指定的信号 Sep 14 01:09:46 Server-108 kill: -q, --queue <信号> 使用 sigqueue(2) 代替 kill(2) Sep 14 01:09:46 Server-108 kill: -p, --pid 打印 pid 而不向它们发送信号 Sep 14 01:09:46 Server-108 kill: -l, --list [=<信号>] 列出信号名,或将一个信号转换为名称 Sep 14 01:09:46 Server-108 kill: -L, --table 列出信号名和数值 Sep 14 01:09:46 Server-108 systemd: zabbix-server.service: control process exited, code=exited status=1 Sep 14 01:09:46 Server-108 kill: -h, --help 显示此帮助并退出 Sep 14 01:09:46 Server-108 kill: -V, --version 输出版本信息并退出 Sep 14 01:09:46 Server-108 kill: 更多信息请参阅 kill(1)。 Sep 14 01:09:46 Server-108 systemd: Unit zabbix-server.service entered failed state. Sep 14 01:09:46 Server-108 systemd: zabbix-server.service failed. Sep 14 01:09:56 Server-108 systemd: zabbix-server.service holdoff time over, scheduling restart. Sep 14 01:09:56 Server-108 systemd: Stopped Zabbix Server. Sep 14 01:09:56 Server-108 systemd: Starting Zabbix Server... Sep 14 01:09:56 Server-108 systemd: zabbix-server.service: Supervising process 29142 which is not our child. We'll most likely not notice when it exits. Sep 14 01:09:56 Server-108 systemd: Started Zabbix Server. Sep 14 01:10:16 Server-108 kill: 用法: Sep 14 01:10:16 Server-108 kill: kill [选项] <pid|名称> [...] Sep 14 01:10:16 Server-108 kill: 选项: Sep 14 01:10:16 Server-108 kill: -a, --all 不限于只对和当前进程的用户 id 相同的进程进行 Sep 14 01:10:16 Server-108 kill: 名称-进程id 转换 Sep 14 01:10:16 Server-108 kill: -s, --signal <信号> 发送指定的信号 Sep 14 01:10:16 Server-108 kill: -q, --queue <信号> 使用 sigqueue(2) 代替 kill(2) Sep 14 01:10:16 Server-108 kill: -p, --pid 打印 pid 而不向它们发送信号 Sep 14 01:10:16 Server-108 kill: -l, --list [=<信号>] 列出信号名,或将一个信号转换为名称 Sep 14 01:10:16 Server-108 kill: -L, --table 列出信号名和数值 Sep 14 01:10:16 Server-108 systemd: zabbix-server.service: control process exited, code=exited status=1 Sep 14 01:10:16 Server-108 kill: -h, --help 显示此帮助并退出 Sep 14 01:10:16 Server-108 kill: -V, --version 输出版本信息并退出 Sep 14 01:10:16 Server-108 kill: 更多信息请参阅 kill(1)。 Sep 14 01:10:16 Server-108 systemd: Unit zabbix-server.service entered failed state. Sep 14 01:10:16 Server-108 systemd: zabbix-server.service failed. Sep 14 01:10:26 Server-108 systemd: zabbix-server.service holdoff time over, scheduling restart. Sep 14 01:10:26 Server-108 systemd: Stopped Zabbix Server. Sep 14 01:10:26 Server-108 systemd: Starting Zabbix Server... Sep 14 01:10:26 Server-108 systemd: zabbix-server.service: Supervising process 29312 which is not our child. We'll most likely not notice when it exits. Sep 14 01:10:26 Server-108 systemd: Started Zabbix Server. Sep 14 01:10:46 Server-108 kill: 用法: Sep 14 01:10:46 Server-108 kill: kill [选项] <pid|名称> [...] Sep 14 01:10:46 Server-108 kill: 选项: Sep 14 01:10:46 Server-108 kill: -a, --all 不限于只对和当前进程的用户 id 相同的进程进行 Sep 14 01:10:46 Server-108 kill: 名称-进程id 转换 Sep 14 01:10:46 Server-108 kill: -s, --signal <信号> 发送指定的信号 Sep 14 01:10:46 Server-108 kill: -q, --queue <信号> 使用 sigqueue(2) 代替 kill(2) Sep 14 01:10:46 Server-108 kill: -p, --pid 打印 pid 而不向它们发送信号 Sep 14 01:10:46 Server-108 kill: -l, --list [=<信号>] 列出信号名,或将一个信号转换为名称 Sep 14 01:10:46 Server-108 kill: -L, --table 列出信号名和数值 Sep 14 01:10:46 Server-108 kill: -h, --help 显示此帮助并退出 Sep 14 01:10:46 Server-108 kill: -V, --version 输出版本信息并退出 Sep 14 01:10:46 Server-108 kill: 更多信息请参阅 kill(1)。 Sep 14 01:10:46 Server-108 systemd: zabbix-server.service: control process exited, code=exited status=1 Sep 14 01:10:46 Server-108 systemd: Unit zabbix-server.service entered failed state. Sep 14 01:10:46 Server-108 systemd: zabbix-server.service failed. Sep 14 01:10:56 Server-108 systemd: zabbix-server.service holdoff time over, scheduling restart. Sep 14 01:10:56 Server-108 systemd: Stopped Zabbix Server. Sep 14 01:10:56 Server-108 systemd: Starting Zabbix Server... Sep 14 01:10:56 Server-108 systemd: zabbix-server.service: Supervising process 29492 which is not our child. We'll most likely not notice when it exits. Sep 14 01:10:56 Server-108 systemd: Started Zabbix Server. Sep 14 01:11:00 Server-108 dhclient[8901]: DHCPREQUEST on eth1 to 192.168.161.254 port 67 (xid=0x52a27475) Sep 14 01:11:00 Server-108 dhclient[8901]: DHCPACK from 192.168.161.254 (xid=0x52a27475) Sep 14 01:11:02 Server-108 dhclient[8901]: bound to 192.168.161.128 -- renewal in 808 seconds. Sep 14 01:11:16 Server-108 kill: 用法: Sep 14 01:11:16 Server-108 kill: kill [选项] <pid|名称> [...] Sep 14 01:11:16 Server-108 kill: 选项: Sep 14 01:11:16 Server-108 kill: -a, --all 不限于只对和当前进程的用户 id 相同的进程进行 Sep 14 01:11:16 Server-108 kill: 名称-进程id 转换 Sep 14 01:11:16 Server-108 systemd: zabbix-server.service: control process exited, code=exited status=1 Sep 14 01:11:16 Server-108 kill: -s, --signal <信号> 发送指定的信号 Sep 14 01:11:16 Server-108 kill: -q, --queue <信号> 使用 sigqueue(2) 代替 kill(2) Sep 14 01:11:16 Server-108 kill: -p, --pid 打印 pid 而不向它们发送信号 Sep 14 01:11:16 Server-108 kill: -l, --list [=<信号>] 列出信号名,或将一个信号转换为名称 Sep 14 01:11:16 Server-108 kill: -L, --table 列出信号名和数值 Sep 14 01:11:16 Server-108 kill: -h, --help 显示此帮助并退出 Sep 14 01:11:16 Server-108 kill: -V, --version 输出版本信息并退出 Sep 14 01:11:16 Server-108 kill: 更多信息请参阅 kill(1)。 Sep 14 01:11:16 Server-108 systemd: Unit zabbix-server.service entered failed state. Sep 14 01:11:16 Server-108 systemd: zabbix-server.service failed. Sep 14 01:11:26 Server-108 systemd: zabbix-server.service holdoff time over, scheduling restart
29887:20190914:011216.505 Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x60]. Crashing ... 29887:20190914:011216.505 ====== Fatal information: ====== 29887:20190914:011216.505 Program counter: 0x7f6cbce7e8f7 29887:20190914:011216.505 === Registers: === 29887:20190914:011216.505 r8 = 0 = 0 = 0 29887:20190914:011216.505 r9 = 10 = 16 = 16 29887:20190914:011216.505 r10 = 7ffd96dfe160 = 140727134708064 = 140727134708064 29887:20190914:011216.505 r11 = 7f6cfd120dc0 = 140106079014336 = 140106079014336 29887:20190914:011216.505 r12 = 7ffd96dfe740 = 140727134709568 = 140727134709568 29887:20190914:011216.505 r13 = 3f = 63 = 63 29887:20190914:011216.505 r14 = 56105d47bd58 = 94628284448088 = 94628284448088 29887:20190914:011216.505 r15 = 7ffd96dfe8dc = 140727134709980 = 140727134709980 29887:20190914:011216.505 rdi = 7f6d00a3e120 = 140106138902816 = 140106138902816 29887:20190914:011216.506 rsi = 7ffd96dfe740 = 140727134709568 = 140727134709568 29887:20190914:011216.506 rbp = 7ffd96dfe870 = 140727134709872 = 140727134709872 29887:20190914:011216.506 rbx = 7ffd96dfe738 = 140727134709560 = 140727134709560 29887:20190914:011216.506 rdx = 616e6962 = 1634625890 = 1634625890 29887:20190914:011216.506 rax = 0 = 0 = 0 29887:20190914:011216.506 rcx = 7972616e = 2037539182 = 2037539182 29887:20190914:011216.506 rsp = 7ffd96dfe730 = 140727134709552 = 140727134709552 29887:20190914:011216.506 rip = 7f6cbce7e8f7 = 140105002510583 = 140105002510583 29887:20190914:011216.506 efl = 10202 = 66050 = 66050 29887:20190914:011216.506 csgsfs = 33 = 51 = 51 29887:20190914:011216.506 err = 4 = 4 = 4 29887:20190914:011216.506 trapno = e = 14 = 14 29887:20190914:011216.506 oldmask = 0 = 0 = 0 29887:20190914:011216.506 cr2 = 60 = 96 = 96 29887:20190914:011216.506 === Backtrace: === 29887:20190914:011216.507 27: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](zbx_backtrace+0x42) [0x56105cb4b680] 29887:20190914:011216.507 26: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](zbx_log_fatal_info+0x151) [0x56105cb4b8fe] 29887:20190914:011216.507 25: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](+0x100c96) [0x56105cb4bc96] 29887:20190914:011216.507 24: /lib64/libpthread.so.0(+0xf5d0) [0x7f6d003275d0] 29887:20190914:011216.507 23: /usr/lib64/libmyodbc8w.so(+0xb18f7) [0x7f6cbce7e8f7] 29887:20190914:011216.507 22: /usr/lib64/libmyodbc8w.so(_Z22add_compiled_collationP12CHARSET_INFO+0x25) [0x7f6cbce7f2c5] 29887:20190914:011216.508 21: /usr/lib64/libmyodbc8w.so(_Z22init_compiled_charsetsi+0x15) [0x7f6cbce7f305] 29887:20190914:011216.508 20: /usr/lib64/libmyodbc8w.so(+0xb0ccc) [0x7f6cbce7dccc] 29887:20190914:011216.508 19: /lib64/libpthread.so.0(pthread_once+0x50) [0x7f6d00324e40] 29887:20190914:011216.508 18: /usr/lib64/libmyodbc8w.so(_ZSt9call_onceIRFvvEJEEvRSt9once_flagOT_DpOT0_+0x69) [0x7f6cbce7d7e9] 29887:20190914:011216.508 17: /usr/lib64/libmyodbc8w.so(_Z22my_charset_get_by_nameP17MY_CHARSET_LOADERPKcji+0x40) [0x7f6cbce7e420] 29887:20190914:011216.508 16: /usr/lib64/libmyodbc8w.so(_Z21get_charset_by_csnamePKcji+0x4a) [0x7f6cbce7e50a] 29887:20190914:011216.508 15: /usr/lib64/libmyodbc8w.so(myodbc_init+0x14e) [0x7f6cbce3c0f8] 29887:20190914:011216.508 14: /usr/lib64/libmyodbc8w.so(my_SQLAllocEnv+0x1c) [0x7f6cbce3f965] 29887:20190914:011216.508 13: /usr/lib64/libmyodbc8w.so(SQLAllocHandle+0x5c) [0x7f6cbce409fb] 29887:20190914:011216.508 12: /lib64/libodbc.so.2(+0xd8dc) [0x7f6cfed558dc] 29887:20190914:011216.508 11: /lib64/libodbc.so.2(SQLConnect+0x1a7) [0x7f6cfed57af7] 29887:20190914:011216.508 10: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](zbx_odbc_connect+0x1e1) [0x56105cad891f] 29887:20190914:011216.508 9: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](get_value_db+0x22f) [0x56105caa980f] 29887:20190914:011216.508 8: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](+0x4d3ce) [0x56105ca983ce] 29887:20190914:011216.508 7: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](+0x4fa2f) [0x56105ca9aa2f] 29887:20190914:011216.508 6: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](poller_thread+0x1bc) [0x56105ca9bade] 29887:20190914:011216.508 5: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](zbx_thread_start+0x37) [0x56105cb58f7b] 29887:20190914:011216.508 4: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](MAIN_ZABBIX_ENTRY+0xa9d) [0x56105ca85d1b] 29887:20190914:011216.508 3: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](daemon_start+0x2f6) [0x56105cb4aeae] 29887:20190914:011216.508 2: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](main+0x312) [0x56105ca8527c] 29887:20190914:011216.508 1: /lib64/libc.so.6(__libc_start_main+0xf5) [0x7f6cfcfb63d5] 29887:20190914:011216.508 0: /usr/sbin/zabbix_server: poller #15 [got 0 values in 0.000064 sec, getting values](+0x393a9) [0x56105ca843a9] 29887:20190914:011216.508 === Memory map: === 29887:20190914:011216.508 56105ca4b000-56105cc9f000 r-xp 00000000 08:02 67802852 /usr/sbin/zabbix_server_mysql 29887:20190914:011216.508 56105ce9e000-56105cf09000 r--p 00253000 08:02 67802852 /usr/sbin/zabbix_server_mysql 29887:20190914:011216.508 56105cf09000-56105cf14000 rw-p 002be000 08:02 67802852 /usr/sbin/zabbix_server_mysql 29887:20190914:011216.508 56105cf14000-56105cf1c000 rw-p 00000000 00:00 0 29887:20190914:011216.509 56105d433000-56105d454000 rw-p 00000000 00:00 0 [heap] 29887:20190914:011216.509 56105d454000-56105d49c000 rw-p 00000000 00:00 0 [heap] 29887:20190914:011216.509 56105d49c000-56105d578000 rw-p 00000000 00:00 0 [heap] 29887:20190914:011216.509 7f6cbcbbb000-7f6cbcbcb000 r-xp 00000000 08:02 67219791 /usr/lib64/libodbcinst.so.2.0.0 29887:20190914:011216.509 7f6cbcbcb000-7f6cbcdcb000 ---p 00010000 08:02 67219791 /usr/lib64/libodbcinst.so.2.0.0 29887:20190914:011216.509 7f6cbcdcb000-7f6cbcdcc000 r--p 00010000 08:02 67219791 /usr/lib64/libodbcinst.so.2.0.0 29887:20190914:011216.509 7f6cbcdcc000-7f6cbcdcd000 rw-p 00011000 08:02 67219791 /usr/lib64/libodbcinst.so.2.0.0 29887:20190914:011216.509 7f6cbcdcd000-7f6cbd1cf000 r-xp 00000000 08:02 67216096 /usr/lib64/libmyodbc8w.so 29887:20190914:011216.509 7f6cbd1cf000-7f6cbd3ce000 ---p 00402000 08:02 67216096 /usr/lib64/libmyodbc8w.so 29887:20190914:011216.509 7f6cbd3ce000-7f6cbd3d3000 r--p 00401000 08:02 67216096 /usr/lib64/libmyodbc8w.so 29887:20190914:011216.509 7f6cbd3d3000-7f6cbd6d4000 rw-p 00406000 08:02 67216096 /usr/lib64/libmyodbc8w.so 29887:20190914:011216.509 7f6cbd6d4000-7f6cbd6da000 rw-p 00000000 00:00 0 29887:20190914:011216.509 7f6cbd6da000-7f6cbd6dc000 r-xp 00000000 08:02 100717472 /usr/lib64/gconv/ISO8859-1.so 29887:20190914:011216.509 7f6cbd6dc000-7f6cbd8db000 ---p 00002000 08:02 100717472 /usr/lib64/gconv/ISO8859-1.so 29887:20190914:011216.509 7f6cbd8db000-7f6cbd8dc000 r--p 00001000 08:02 100717472 /usr/lib64/gconv/ISO8859-1.so 29887:20190914:011216.509 7f6cbd8dc000-7f6cbd8dd000 rw-p 00002000 08:02 100717472 /usr/lib64/gconv/ISO8859-1.so 29887:20190914:011216.509 7f6cbd8dd000-7f6cc3e07000 r--p 00000000 08:02 34165399 /usr/lib/locale/locale-archive 29887:20190914:011216.509 7f6cc3e07000-7f6cd3e07000 rw-s 00000000 00:04 24838150 /SYSV00000000 (deleted) 29887:20190914:011216.509 7f6cd3e07000-7f6ce3e07000 rw-s 00000000 00:04 24772612 /SYSV00000000 (deleted) 29887:20190914:011216.509 7f6ce3e07000-7f6cf3e07000 rw-s 00000000 00:04 24739843 /SYSV00000000 (deleted) 29887:20190914:011216.509 7f6cf3e07000-7f6cf4207000 rw-s 00000000 00:04 24707074 /SYSV00000000 (deleted) 29887:20190914:011216.509 7f6cf4207000-7f6cf8207000 rw-s 00000000 00:04 24674305 /SYSV00000000 (deleted) 29887:20190914:011216.509 7f6cf8207000-7f6cf8213000 r-xp 00000000 08:02 67231613 /usr/lib64/libnss_files-2.17.so 29887:20190914:011216.509 7f6cf8213000-7f6cf8412000 ---p 0000c000 08:02 67231613 /usr/lib64/libnss_files-2.17.so 29887:20190914:011216.509 7f6cf8412000-7f6cf8413000 r--p 0000b000 08:02 67231613 /usr/lib64/libnss_files-2.17.so 29887:20190914:011216.509 7f6cf8413000-7f6cf8414000 rw-p 0000c000 08:02 67231613 /usr/lib64/libnss_files-2.17.so 29887:20190914:011216.509 7f6cf8414000-7f6cf841a000 rw-p 00000000 00:00 0 29887:20190914:011216.509 7f6cf841a000-7f6cf841c000 r-xp 00000000 08:02 67231309 /usr/lib64/libfreebl3.so 29887:20190914:011216.510 7f6cf841c000-7f6cf861b000 ---p 00002000 08:02 67231309 /usr/lib64/libfreebl3.so 29887:20190914:011216.510 7f6cf861b000-7f6cf861c000 r--p 00001000 08:02 67231309 /usr/lib64/libfreebl3.so 29887:20190914:011216.510 7f6cf861c000-7f6cf861d000 rw-p 00002000 08:02 67231309 /usr/lib64/libfreebl3.so 29887:20190914:011216.510 7f6cf861d000-7f6cf8624000 r-xp 00000000 08:02 67262208 /usr/lib64/libffi.so.6.0.1 29887:20190914:011216.510 7f6cf8624000-7f6cf8823000 ---p 00007000 08:02 67262208 /usr/lib64/libffi.so.6.0.1 29887:20190914:011216.510 7f6cf8823000-7f6cf8824000 r--p 00006000 08:02 67262208 /usr/lib64/libffi.so.6.0.1 29887:20190914:011216.510 7f6cf8824000-7f6cf8825000 rw-p 00007000 08:02 67262208 /usr/lib64/libffi.so.6.0.1 29887:20190914:011216.510 7f6cf8825000-7f6cf8849000 r-xp 00000000 08:02 67262211 /usr/lib64/libselinux.so.1 29887:20190914:011216.510 7f6cf8849000-7f6cf8a48000 ---p 00024000 08:02 67262211 /usr/lib64/libselinux.so.1 29887:20190914:011216.510 7f6cf8a48000-7f6cf8a49000 r--p 00023000 08:02 67262211 /usr/lib64/libselinux.so.1 29887:20190914:011216.510 7f6cf8a49000-7f6cf8a4a000 rw-p 00024000 08:02 67262211 /usr/lib64/libselinux.so.1 29887:20190914:011216.510 7f6cf8a4a000-7f6cf8a4c000 rw-p 00000000 00:00 0 29887:20190914:011216.510 7f6cf8a4c000-7f6cf8a53000 r-xp 00000000 08:02 67246465 /usr/lib64/librt-2.17.so 29887:20190914:011216.510 7f6cf8a53000-7f6cf8c52000 ---p 00007000 08:02 67246465 /usr/lib64/librt-2.17.so 29887:20190914:011216.510 7f6cf8c52000-7f6cf8c53000 r--p 00006000 08:02 67246465 /usr/lib64/librt-2.17.so 29887:20190914:011216.510 7f6cf8c53000-7f6cf8c54000 rw-p 00007000 08:02 67246465 /usr/lib64/librt-2.17.so 29887:20190914:011216.510 7f6cf8c54000-7f6cf8c5c000 r-xp 00000000 08:02 67231594 /usr/lib64/libcrypt-2.17.so 29887:20190914:011216.510 7f6cf8c5c000-7f6cf8e5b000 ---p 00008000 08:02 67231594 /usr/lib64/libcrypt-2.17.so 29887:20190914:011216.510 7f6cf8e5b000-7f6cf8e5c000 r--p 00007000 08:02 67231594 /usr/lib64/libcrypt-2.17.so 29887:20190914:011216.510 7f6cf8e5c000-7f6cf8e5d000 rw-p 00008000 08:02 67231594 /usr/lib64/libcrypt-2.17.so 29887:20190914:011216.510 7f6cf8e5d000-7f6cf8e8b000 rw-p 00000000 00:00 0 29887:20190914:011216.510 7f6cf8e8b000-7f6cf8f01000 r-xp 00000000 08:02 67262187 /usr/lib64/libgmp.so.10.2.0 29887:20190914:011216.510 7f6cf8f01000-7f6cf9100000 ---p 00076000 08:02 67262187 /usr/lib64/libgmp.so.10.2.0 29887:20190914:011216.510 7f6cf9100000-7f6cf9102000 r--p 00075000 08:02 67262187 /usr/lib64/libgmp.so.10.2.0 29887:20190914:011216.510 7f6cf9102000-7f6cf9103000 rw-p 00077000 08:02 67262187 /usr/lib64/libgmp.so.10.2.0 29887:20190914:011216.511 7f6cf9103000-7f6cf9129000 r-xp 00000000 08:02 67460286 /usr/lib64/libhogweed.so.2.5 29887:20190914:011216.511 7f6cf9129000-7f6cf9328000 ---p 00026000 08:02 67460286 /usr/lib64/libhogweed.so.2.5 29887:20190914:011216.511 7f6cf9328000-7f6cf9329000 r--p 00025000 08:02 67460286 /usr/lib64/libhogweed.so.2.5 29887:20190914:011216.511 7f6cf9329000-7f6cf932a000 rw-p 00026000 08:02 67460286 /usr/lib64/libhogweed.so.2.5 29887:20190914:011216.511 7f6cf932a000-7f6cf9359000 r-xp 00000000 08:02 67460288 /usr/lib64/libnettle.so.4.7 29887:20190914:011216.511 7f6cf9359000-7f6cf9559000 ---p 0002f000 08:02 67460288 /usr/lib64/libnettle.so.4.7 29887:20190914:011216.511 7f6cf9559000-7f6cf955a000 r--p 0002f000 08:02 67460288 /usr/lib64/libnettle.so.4.7 29887:20190914:011216.511 7f6cf955a000-7f6cf955b000 rw-p 00030000 08:02 67460288 /usr/lib64/libnettle.so.4.7 29887:20190914:011216.511 7f6cf955b000-7f6cf956c000 r-xp 00000000 08:02 67262251 /usr/lib64/libtasn1.so.6.5.3 29887:20190914:011216.511 7f6cf956c000-7f6cf976c000 ---p 00011000 08:02 67262251 /usr/lib64/libtasn1.so.6.5.3 29887:20190914:011216.511 7f6cf976c000-7f6cf976d000 r--p 00011000 08:02 67262251 /usr/lib64/libtasn1.so.6.5.3 29887:20190914:011216.511 7f6cf976d000-7f6cf976e000 rw-p 00012000 08:02 67262251 /usr/lib64/libtasn1.so.6.5.3 29887:20190914:011216.511 7f6cf976e000-7f6cf9888000 r-xp 00000000 08:02 67262246 /usr/lib64/libp11-kit.so.0.3.0 29887:20190914:011216.511 7f6cf9888000-7f6cf9a88000 ---p 0011a000 08:02 67262246 /usr/lib64/libp11-kit.so.0.3.0 29887:20190914:011216.511 7f6cf9a88000-7f6cf9a92000 r--p 0011a000 08:02 67262246 /usr/lib64/libp11-kit.so.0.3.0 29887:20190914:011216.511 7f6cf9a92000-7f6cf9a9c000 rw-p 00124000 08:02 67262246 /usr/lib64/libp11-kit.so.0.3.0 29887:20190914:011216.511 7f6cf9a9c000-7f6cf9a9d000 rw-p 00000000 00:00 0 29887:20190914:011216.511 7f6cf9a9d000-7f6cf9aa0000 r-xp 00000000 08:02 67262263 /usr/lib64/libkeyutils.so.1.5 29887:20190914:011216.511 7f6cf9aa0000-7f6cf9c9f000 ---p 00003000 08:02 67262263 /usr/lib64/libkeyutils.so.1.5 29887:20190914:011216.511 7f6cf9c9f000-7f6cf9ca0000 r--p 00002000 08:02 67262263 /usr/lib64/libkeyutils.so.1.5 29887:20190914:011216.511 7f6cf9ca0000-7f6cf9ca1000 rw-p 00003000 08:02 67262263 /usr/lib64/libkeyutils.so.1.5 29887:20190914:011216.511 7f6cf9ca1000-7f6cf9caf000 r-xp 00000000 08:02 67246488 /usr/lib64/libkrb5support.so.0.1 29887:20190914:011216.511 7f6cf9caf000-7f6cf9eaf000 ---p 0000e000 08:02 67246488 /usr/lib64/libkrb5support.so.0.1 29887:20190914:011216.511 7f6cf9eaf000-7f6cf9eb0000 r--p 0000e000 08:02 67246488 /usr/lib64/libkrb5support.so.0.1 29887:20190914:011216.511 7f6cf9eb0000-7f6cf9eb1000 rw-p 0000f000 08:02 67246488 /usr/lib64/libkrb5support.so.0.1 29887:20190914:011216.511 7f6cf9eb1000-7f6cf9ee3000 r-xp 00000000 08:02 67322677 /usr/lib64/libidn.so.11.6.11 29887:20190914:011216.511 7f6cf9ee3000-7f6cfa0e2000 ---p 00032000 08:02 67322677 /usr/lib64/libidn.so.11.6.11 29887:20190914:011216.511 7f6cfa0e2000-7f6cfa0e3000 r--p 00031000 08:02 67322677 /usr/lib64/libidn.so.11.6.11 29887:20190914:011216.512 7f6cfa0e3000-7f6cfa0e4000 rw-p 00032000 08:02 67322677 /usr/lib64/libidn.so.11.6.11 29887:20190914:011216.512 7f6cfa0e4000-7f6cfa11e000 r-xp 00000000 08:02 67231677 /usr/lib64/libnspr4.so 29887:20190914:011216.512 7f6cfa11e000-7f6cfa31d000 ---p 0003a000 08:02 67231677 /usr/lib64/libnspr4.so 29887:20190914:011216.512 7f6cfa31d000-7f6cfa31e000 r--p 00039000 08:02 67231677 /usr/lib64/libnspr4.so 29887:20190914:011216.512 7f6cfa31e000-7f6cfa320000 rw-p 0003a000 08:02 67231677 /usr/lib64/libnspr4.so 29887:20190914:011216.512 7f6cfa320000-7f6cfa322000 rw-p 00000000 00:00 0 29887:20190914:011216.512 7f6cfa322000-7f6cfa326000 r-xp 00000000 08:02 67231678 /usr/lib64/libplc4.so 29887:20190914:011216.512 7f6cfa326000-7f6cfa525000 ---p 00004000 08:02 67231678 /usr/lib64/libplc4.so 29887:20190914:011216.512 7f6cfa525000-7f6cfa526000 r--p 00003000 08:02 67231678 /usr/lib64/libplc4.so 29887:20190914:011216.512 7f6cfa526000-7f6cfa527000 rw-p 00004000 08:02 67231678 /usr/lib64/libplc4.so 29887:20190914:011216.512 7f6cfa527000-7f6cfa52a000 r-xp 00000000 08:02 67231679 /usr/lib64/libplds4.so 29887:20190914:011216.512 7f6cfa52a000-7f6cfa729000 ---p 00003000 08:02 67231679 /usr/lib64/libplds4.so 29887:20190914:011216.512 7f6cfa729000-7f6cfa72a000 r--p 00002000 08:02 67231679 /usr/lib64/libplds4.so 29887:20190914:011216.512 7f6cfa72a000-7f6cfa72b000 rw-p 00003000 08:02 67231679 /usr/lib64/libplds4.so 29887:20190914:011216.512 7f6cfa72b000-7f6cfa753000 r-xp 00000000 08:02 67262177 /usr/lib64/libnssutil3.so 29887:20190914:011216.512 7f6cfa753000-7f6cfa952000 ---p 00028000 08:02 67262177 /usr/lib64/libnssutil3.so 29887:20190914:011216.512 7f6cfa952000-7f6cfa959000 r--p 00027000 08:02 67262177 /usr/lib64/libnssutil3.so 29887:20190914:011216.512 7f6cfa959000-7f6cfa95a000 rw-p 0002e000 08:02 67262177 /usr/lib64/libnssutil3.so 29887:20190914:011216.512 7f6cfa95a000-7f6cfaa7e000 r-xp 00000000 08:02 67322659 /usr/lib64/libnss3.so 29887:20190914:011216.512 7f6cfaa7e000-7f6cfac7e000 ---p 00124000 08:02 67322659 /usr/lib64/libnss3.so 29887:20190914:011216.512 7f6cfac7e000-7f6cfac83000 r--p 00124000 08:02 67322659 /usr/lib64/libnss3.so 29887:20190914:011216.512 7f6cfac83000-7f6cfac85000 rw-p 00129000 08:02 67322659 /usr/lib64/libnss3.so 29887:20190914:011216.512 7f6cfac85000-7f6cfac87000 rw-p 00000000 00:00 0 29887:20190914:011216.512 7f6cfac87000-7f6cfacab000 r-xp 00000000 08:02 67322660 /usr/lib64/libsmime3.so 29887:20190914:011216.512 7f6cfacab000-7f6cfaeaa000 ---p 00024000 08:02 67322660 /usr/lib64/libsmime3.so 29887:20190914:011216.512 7f6cfaeaa000-7f6cfaead000 r--p 00023000 08:02 67322660 /usr/lib64/libsmime3.so 29887:20190914:011216.512 7f6cfaead000-7f6cfaeae000 rw-p 00026000 08:02 67322660 /usr/lib64/libsmime3.so 29887:20190914:011216.513 7f6cfaeae000-7f6cfaefb000 r-xp 00000000 08:02 67322661 /usr/lib64/libssl3.so 29887:20190914:011216.513 7f6cfaefb000-7f6cfb0fa000 ---p 0004d000 08:02 67322661 /usr/lib64/libssl3.so 29887:20190914:011216.513 7f6cfb0fa000-7f6cfb0fe000 r--p 0004c000 08:02 67322661 /usr/lib64/libssl3.so 29887:20190914:011216.513 7f6cfb0fe000-7f6cfb0ff000 rw-p 00050000 08:02 67322661 /usr/lib64/libssl3.so 29887:20190914:011216.513 7f6cfb0ff000-7f6cfb100000 rw-p 00000000 00:00 0 29887:20190914:011216.513 7f6cfb100000-7f6cfb11c000 r-xp 00000000 08:02 67273158 /usr/lib64/libsasl2.so.3.0.0 29887:20190914:011216.513 7f6cfb11c000-7f6cfb31b000 ---p 0001c000 08:02 67273158 /usr/lib64/libsasl2.so.3.0.0 29887:20190914:011216.513 7f6cfb31b000-7f6cfb31c000 r--p 0001b000 08:02 67273158 /usr/lib64/libsasl2.so.3.0.0 29887:20190914:011216.513 7f6cfb31c000-7f6cfb31d000 rw-p 0001c000 08:02 67273158 /usr/lib64/libsasl2.so.3.0.0 29887:20190914:011216.513 7f6cfb31d000-7f6cfb324000 r-xp 00000000 08:02 67287564 /usr/lib64/libgdbm.so.4.0.0 29887:20190914:011216.513 7f6cfb324000-7f6cfb524000 ---p 00007000 08:02 67287564 /usr/lib64/libgdbm.so.4.0.0 29887:20190914:011216.513 7f6cfb524000-7f6cfb525000 r--p 00007000 08:02 67287564 /usr/lib64/libgdbm.so.4.0.0 29887:20190914:011216.513 7f6cfb525000-7f6cfb526000 rw-p 00008000 08:02 67287564 /usr/lib64/libgdbm.so.4.0.0 29887:20190914:011216.513 7f6cfb526000-7f6cfb52e000 r-xp 00000000 08:02 67219900 /usr/lib64/libOpenIPMIutils.so.0.0.1 29887:20190914:011216.513 7f6cfb52e000-7f6cfb72e000 ---p 00008000 08:02 67219900 /usr/lib64/libOpenIPMIutils.so.0.0.1 29887:20190914:011216.513 7f6cfb72e000-7f6cfb72f000 r--p 00008000 08:02 67219900 /usr/lib64/libOpenIPMIutils.so.0.0.1 29887:20190914:011216.513 7f6cfb72f000-7f6cfb730000 rw-p 00009000 08:02 67219900 /usr/lib64/libOpenIPMIutils.so.0.0.1 29887:20190914:011216.513 7f6cfb730000-7f6cfb739000 r-xp 00000000 08:02 67322370 /usr/lib64/libltdl.so.7.3.0 29887:20190914:011216.513 7f6cfb739000-7f6cfb938000 ---p 00009000 08:02 67322370 /usr/lib64/libltdl.so.7.3.0 29887:20190914:011216.513 7f6cfb938000-7f6cfb939000 r--p 00008000 08:02 67322370 /usr/lib64/libltdl.so.7.3.0 29887:20190914:011216.513 7f6cfb939000-7f6cfb93a000 rw-p 00009000 08:02 67322370 /usr/lib64/libltdl.so.7.3.0 29887:20190914:011216.513 7f6cfb93a000-7f6cfb95f000 r-xp 00000000 08:02 67273047 /usr/lib64/liblzma.so.5.2.2 29887:20190914:011216.513 7f6cfb95f000-7f6cfbb5e000 ---p 00025000 08:02 67273047 /usr/lib64/liblzma.so.5.2.2 29887:20190914:011216.513 7f6cfbb5e000-7f6cfbb5f000 r--p 00024000 08:02 67273047 /usr/lib64/liblzma.so.5.2.2 29887:20190914:011216.513 7f6cfbb5f000-7f6cfbb60000 rw-p 00025000 08:02 67273047 /usr/lib64/liblzma.so.5.2.2 29887:20190914:011216.513 7f6cfbb60000-7f6cfbb64000 r-xp 00000000 08:02 67273097 /usr/lib64/libgpg-error.so.0.10.0 29887:20190914:011216.513 7f6cfbb64000-7f6cfbd63000 ---p 00004000 08:02 67273097 /usr/lib64/libgpg-error.so.0.10.0 29887:20190914:011216.513 7f6cfbd63000-7f6cfbd64000 r--p 00003000 08:02 67273097 /usr/lib64/libgpg-error.so.0.10.0 29887:20190914:011216.514 7f6cfbd64000-7f6cfbd65000 rw-p 00004000 08:02 67273097 /usr/lib64/libgpg-error.so.0.10.0 29887:20190914:011216.514 7f6cfbd65000-7f6cfbde2000 r-xp 00000000 08:02 67273086 /usr/lib64/libgcrypt.so.11.8.2 29887:20190914:011216.514 7f6cfbde2000-7f6cfbfe1000 ---p 0007d000 08:02 67273086 /usr/lib64/libgcrypt.so.11.8.2 29887:20190914:011216.514 7f6cfbfe1000-7f6cfbfe2000 r--p 0007c000 08:02 67273086 /usr/lib64/libgcrypt.so.11.8.2 29887:20190914:011216.514 7f6cfbfe2000-7f6cfbfe5000 rw-p 0007d000 08:02 67273086 /usr/lib64/libgcrypt.so.11.8.2 29887:20190914:011216.514 7f6cfbfe5000-7f6cfbfe6000 rw-p 00000000 00:00 0 29887:20190914:011216.514 7f6cfbfe6000-7f6cfc114000 r-xp 00000000 08:02 67599294 /usr/lib64/libgnutls.so.28.43.3 29887:20190914:011216.514 7f6cfc114000-7f6cfc313000 ---p 0012e000 08:02 67599294 /usr/lib64/libgnutls.so.28.43.3 29887:20190914:011216.514 7f6cfc313000-7f6cfc31d000 r--p 0012d000 08:02 67599294 /usr/lib64/libgnutls.so.28.43.3 29887:20190914:011216.514 7f6cfc31d000-7f6cfc31f000 rw-p 00137000 08:02 67599294 /usr/lib64/libgnutls.so.28.43.3 29887:20190914:011216.514 7f6cfc31f000-7f6cfc320000 rw-p 00000000 00:00 0 29887:20190914:011216.514 7f6cfc320000-7f6cfc351000 r-xp 00000000 08:02 67246480 /usr/lib64/libk5crypto.so.3.1 29887:20190914:011216.514 7f6cfc351000-7f6cfc550000 ---p 00031000 08:02 67246480 /usr/lib64/libk5crypto.so.3.1 29887:20190914:011216.514 7f6cfc550000-7f6cfc552000 r--p 00030000 08:02 67246480 /usr/lib64/libk5crypto.so.3.1 29887:20190914:011216.514 7f6cfc552000-7f6cfc553000 rw-p 00032000 08:02 67246480 /usr/lib64/libk5crypto.so.3.1 29887:20190914:011216.514 7f6cfc553000-7f6cfc556000 r-xp 00000000 08:02 67262186 /usr/lib64/libcom_err.so.2.1 29887:20190914:011216.514 7f6cfc556000-7f6cfc755000 ---p 00003000 08:02 67262186 /usr/lib64/libcom_err.so.2.1 29887:20190914:011216.514 7f6cfc755000-7f6cfc756000 r--p 00002000 08:02 67262186 /usr/lib64/libcom_err.so.2.1 29887:20190914:011216.514 7f6cfc756000-7f6cfc757000 rw-p 00003000 08:02 67262186 /usr/lib64/libcom_err.so.2.1 29887:20190914:011216.514 7f6cfc757000-7f6cfc830000 r-xp 00000000 08:02 67246486 /usr/lib64/libkrb5.so.3.3 29887:20190914:011216.514 7f6cfc830000-7f6cfca2f000 ---p 000d9000 08:02 67246486 /usr/lib64/libkrb5.so.3.3 29887:20190914:011216.514 7f6cfca2f000-7f6cfca3d000 r--p 000d8000 08:02 67246486 /usr/lib64/libkrb5.so.3.3 29887:20190914:011216.514 7f6cfca3d000-7f6cfca40000 rw-p 000e6000 08:02 67246486 /usr/lib64/libkrb5.so.3.3 29887:20190914:011216.514 7f6cfca40000-7f6cfca8a000 r-xp 00000000 08:02 67231639 /usr/lib64/libgssapi_krb5.so.2.2 29887:20190914:011216.514 7f6cfca8a000-7f6cfcc8a000 ---p 0004a000 08:02 67231639 /usr/lib64/libgssapi_krb5.so.2.2 29887:20190914:011216.515 7f6cfcc8a000-7f6cfcc8b000 r--p 0004a000 08:02 67231639 /usr/lib64/libgssapi_krb5.so.2.2 29887:20190914:011216.515 7f6cfcc8b000-7f6cfcc8d000 rw-p 0004b000 08:02 67231639 /usr/lib64/libgssapi_krb5.so.2.2 29887:20190914:011216.515 7f6cfcc8d000-7f6cfcd76000 r-xp 00000000 08:02 67161268 /usr/lib64/libstdc++.so.6.0.19 29887:20190914:011216.515 7f6cfcd76000-7f6cfcf75000 ---p 000e9000 08:02 67161268 /usr/lib64/libstdc++.so.6.0.19 29887:20190914:011216.515 7f6cfcf75000-7f6cfcf7d000 r--p 000e8000 08:02 67161268 /usr/lib64/libstdc++.so.6.0.19 29887:20190914:011216.515 7f6cfcf7d000-7f6cfcf7f000 rw-p 000f0000 08:02 67161268 /usr/lib64/libstdc++.so.6.0.19 29887:20190914:011216.515 7f6cfcf7f000-7f6cfcf94000 rw-p 00000000 00:00 0 29887:20190914:011216.515 7f6cfcf94000-7f6cfd156000 r-xp 00000000 08:02 67231304 /usr/lib64/libc-2.17.so 29887:20190914:011216.515 7f6cfd156000-7f6cfd356000 ---p 001c2000 08:02 67231304 /usr/lib64/libc-2.17.so 29887:20190914:011216.515 7f6cfd356000-7f6cfd35a000 r--p 001c2000 08:02 67231304 /usr/lib64/libc-2.17.so 29887:20190914:011216.515 7f6cfd35a000-7f6cfd35c000 rw-p 001c6000 08:02 67231304 /usr/lib64/libc-2.17.so 29887:20190914:011216.515 7f6cfd35c000-7f6cfd361000 rw-p 00000000 00:00 0 29887:20190914:011216.515 7f6cfd361000-7f6cfd376000 r-xp 00000000 08:02 67160133 /usr/lib64/libgcc_s-4.8.5-20150702.so.1 29887:20190914:011216.515 7f6cfd376000-7f6cfd575000 ---p 00015000 08:02 67160133 /usr/lib64/libgcc_s-4.8.5-20150702.so.1 29887:20190914:011216.515 7f6cfd575000-7f6cfd576000 r--p 00014000 08:02 67160133 /usr/lib64/libgcc_s-4.8.5-20150702.so.1 29887:20190914:011216.515 7f6cfd576000-7f6cfd577000 rw-p 00015000 08:02 67160133 /usr/lib64/libgcc_s-4.8.5-20150702.so.1 29887:20190914:011216.515 7f6cfd577000-7f6cfd5d7000 r-xp 00000000 08:02 67262210 /usr/lib64/libpcre.so.1.2.0 29887:20190914:011216.515 7f6cfd5d7000-7f6cfd7d7000 ---p 00060000 08:02 67262210 /usr/lib64/libpcre.so.1.2.0 29887:20190914:011216.515 7f6cfd7d7000-7f6cfd7d8000 r--p 00060000 08:02 67262210 /usr/lib64/libpcre.so.1.2.0 29887:20190914:011216.515 7f6cfd7d8000-7f6cfd7d9000 rw-p 00061000 08:02 67262210 /usr/lib64/libpcre.so.1.2.0 29887:20190914:011216.515 7f6cfd7d9000-7f6cfd7ef000 r-xp 00000000 08:02 67231625 /usr/lib64/libresolv-2.17.so 29887:20190914:011216.515 7f6cfd7ef000-7f6cfd9ee000 ---p 00016000 08:02 67231625 /usr/lib64/libresolv-2.17.so 29887:20190914:011216.515 7f6cfd9ee000-7f6cfd9ef000 r--p 00015000 08:02 67231625 /usr/lib64/libresolv-2.17.so 29887:20190914:011216.515 7f6cfd9ef000-7f6cfd9f0000 rw-p 00016000 08:02 67231625 /usr/lib64/libresolv-2.17.so 29887:20190914:011216.515 7f6cfd9f0000-7f6cfd9f2000 rw-p 00000000 00:00 0 29887:20190914:011216.515 7f6cfd9f2000-7f6cfda58000 r-xp 00000000 08:02 67424685 /usr/lib64/libcurl.so.4.3.0 29887:20190914:011216.515 7f6cfda58000-7f6cfdc57000 ---p 00066000 08:02 67424685 /usr/lib64/libcurl.so.4.3.0 29887:20190914:011216.516 7f6cfdc57000-7f6cfdc59000 r--p 00065000 08:02 67424685 /usr/lib64/libcurl.so.4.3.0 29887:20190914:011216.516 7f6cfdc59000-7f6cfdc5a000 rw-p 00067000 08:02 67424685 /usr/lib64/libcurl.so.4.3.0 29887:20190914:011216.516 7f6cfdc5a000-7f6cfdc5b000 rw-p 00000000 00:00 0 29887:20190914:011216.516 7f6cfdc5b000-7f6cfdc69000 r-xp 00000000 08:02 67424727 /usr/lib64/liblber-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfdc69000-7f6cfde68000 ---p 0000e000 08:02 67424727 /usr/lib64/liblber-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfde68000-7f6cfde69000 r--p 0000d000 08:02 67424727 /usr/lib64/liblber-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfde69000-7f6cfde6a000 rw-p 0000e000 08:02 67424727 /usr/lib64/liblber-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfde6a000-7f6cfdebc000 r-xp 00000000 08:02 67424729 /usr/lib64/libldap-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfdebc000-7f6cfe0bc000 ---p 00052000 08:02 67424729 /usr/lib64/libldap-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfe0bc000-7f6cfe0be000 r--p 00052000 08:02 67424729 /usr/lib64/libldap-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfe0be000-7f6cfe0bf000 rw-p 00054000 08:02 67424729 /usr/lib64/libldap-2.4.so.2.10.7 29887:20190914:011216.516 7f6cfe0bf000-7f6cfe105000 r-xp 00000000 08:02 67542166 /usr/lib64/libevent-2.0.so.5.1.9 29887:20190914:011216.516 7f6cfe105000-7f6cfe304000 ---p 00046000 08:02 67542166 /usr/lib64/libevent-2.0.so.5.1.9 29887:20190914:011216.516 7f6cfe304000-7f6cfe305000 r--p 00045000 08:02 67542166 /usr/lib64/libevent-2.0.so.5.1.9 29887:20190914:011216.519 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall] 29887:20190914:011216.519 ================================ 29887:20190914:011216.519 Please consider attaching a disassembly listing to your bug report. 29887:20190914:011216.519 This listing can be produced with, e.g., objdump -DSswx zabbix_server. 29887:20190914:011216.519 ================================ 29850:20190914:011216.520 One child process died (PID:29887,exitcode/signal:1). Exiting ... zabbix_server [29850]: Error waiting for process with PID 29887: [10] No child processes 29850:20190914:011216.539 syncing trend data... 29850:20190914:011216.539 syncing trend data done
[Unit]
After=syslog.target
[Service]
Type=forking
Restart=on-failure
RestartSec=10s
TimeoutSec=0
[Install]
[CODE]
Server-108 ~: vim /etc/zabbix/zabbix_server.conf LogFile=/var/log/zabbix/zabbix_server.log LogFileSize=0 PidFile=/var/run/zabbix/zabbix_server.pid SocketDir=/var/run/zabbix DBHost=127.0.0.1 DBName=zabbix DBUser=zabbix DBPassword=zabbix DBPort=3306 StartPollers=100 StartIPMIPollers=0 StartPollersUnreachable=10 StartTrappers=10 StartPingers=10 StartDiscoverers=10 SNMPTrapperFile=/var/log/snmptrap/snmptrap.log CacheSize=256M HistoryCacheSize=64M TrendCacheSize=256M ValueCacheSize=256M Timeout=3 Timeout=4 AlertScriptsPath=/usr/lib/zabbix/alertscripts ExternalScripts=/usr/lib/zabbix/externalscripts LogSlowQueries=3000
