Hello everyone, I'm monitoring a PostgreSQL11 database on Zabbix 4.2.6 with the following template (https://git.zabbix.com/projects/ZBX/.../db/postgresql), and everything works correctly, but in my dashboard appears the following trigger:
This is the internal configuration of the template:
And this is the configuration of the item where this trigger is activated:
It's my only Zabbix server and we don't have replication activated with another server. What do you recommend me to do? Should I deactivate this trigger or should I correct something in the template or script that serves to monitor PostgreSQL?
Thank you.
- "PostgreSQL: Streaming lag with {#MASTER} is too high (over 10m in 5m)"
- Name: PostgreSQL: Streaming lag with {#MASTER} is too high (over {$PG.REPL_LAG.MAX.WARN} in 5m)
- Expression: {Zabbix server: pgsql.replication.lag.sec["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"].min(5m)} > {$PG.REPL_LAG.MAX.WARN} {$PG.REPL_LAG.MAX.WARN}
- Name: Replication: lag in seconds
- Type: Zabbix Agent
- Key: pgsql.replication.lag.sec["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]
- Host interface: 127.0.0.1 10050
- Type of information: Numeric (float)
- Units: s
Thank you.
