Hello, i have a question, is it possible to monitor when a file STOP being changed ?
For example, i have a file here (log) that when stops changing means the service has a problem, so i need to check every X minutes if the file is changing.
I used the "passwd" logic, but have no idea how to do the trigger.
The item i did this:
vfs.file.cksum[E:\Sistemas\Gecex\Gecex_Prod\Gecex\servico.log]
and the trigger this
{fsserver:vfs.file.cksum[E:\Sistemas\Gecex\Gecex_Prod\Gecex\servico.log].diff(0)}>0
Doing this i will have an incident all the time.
Any ideas how i can do this ?
